banks power pda trouble - Ford Truck Enthusiasts Forums
Old 10-09-2009, 10:40 PM
speedracer1000's Avatar
speedracer1000 speedracer1000 is offline
speedracer1000 is starting off with a positive reputation.
ok so i finally got my truck put back together tonight after installin head studs and gaskets, egr cooler delete. oil cooler. and the truck has been sittin with the batteries unhooked for roughly a month.ive had the banks six gun power pda tuner on it for a little over a year. but when i first pulled it in to do all the work. i shut the pda off and havent touched it till tonight. well i went to start it tonight and it must have came on after i hooked up the batteries and its froze and wont do nothin. its stuck on the preferances screen. none of the buttons work, the touch screen doesnt work either.i tried resettin it about 10 times, it resets and goes right back to that screen. i tried taking the sd card out. makes no difference. does anyone know whats goin on or had a similar experience.. btw the truck runs great, and fired right up after about 3 15 second cranks. but the pda is my gauges and everything for now so i kinda need it.
Old 10-10-2009, 12:03 AM
jlmotox's Avatar
jlmotox jlmotox is offline
jlmotox is gaining momentum as a positive member of FTE.jlmotox is gaining momentum as a positive member of FTE.
when I had my banks pda it would freeze every once and awhile but pushing the little reset button on the back would fix it...I also had a problem with the sticky tape holding the pda to the dash coming loose and letting it fall and after enough times falling it pulled a wire out of the phone jack looking plug on the dock and caused it to freeze up and or not connect to the tuner...
or call banks, I called once and got helpful service...
Old 10-10-2009, 09:49 AM
yea its still froze after pushing the reset button. ill have to wait till monday to call banks though. thats what sucks.
Old 10-30-2009, 08:44 PM
cmfd70 cmfd70 is offline
cmfd70 is starting off with a positive reputation.
PDA freezing up?
What was the cause of the PDA freezing up?
Won't start, possible glow plug issue 04F250Harley 6.0L Power Stroke Diesel 9 05-22-2014 09:34 PM
Excursion right brake overheating, pulling left PDA1 Excursion - King of SUVs 7 02-15-2011 11:23 AM
Banks six gun elyrain Computer Chips & Tuners 10 05-08-2010 06:52 AM
Trouble code P2290 ICP???? Dustball8504 6.0L Power Stroke Diesel 4 09-24-2007 10:41 PM
SCT or Banks six-gun?? 18vtx00 6.0L Power Stroke Diesel 19 02-07-2007 04:15 PM
Tags
60, back, banks, connect, deisel, ford, gun, pda, power, reviews, trouble, troubles, tuner, turbo, updates
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
