Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
f500/550
Old 10-09-2009, 09:30 PM
dieselkid's Avatar
dieselkid
dieselkid is offline
f500/550
so here in about 8month ill have the money to buy a new truck, and i was looking into all the trucks i coudl buy with aroudn 10g... 2001 and under 250/ 350/450(dually) and i saw a 2003ish f550 dually 0.o...
so i was wondering wut the difference between the f550 and the f350 duallys?? if i get one itll have a 7.3powerstroke, dually, 4door, and a standard tranny, oh and just a regular pickup bed (can i take a flatbed and put a f350 bed on it?). how do the 2 truck compair.... mpg, engine, tranny, diffs, hight, heavist tow load, ect... any info wut so ever woudl be kool
Old 10-12-2009, 09:58 PM
bigfordmatt's Avatar
bigfordmatt
bigfordmatt is offline
well i bought a 99 550 and well u can put the different cabs and stuff its all in what u wanna do to the truck and how much time or money to put into it mine has a pickup bed on it bud i had to make it fit. there is a few different ways to make this work and i will fill u in more if u would like. but the width and stuff are the same just different bolt partterns on the rims and the rearends are totally different and a lot bigger on the 550 milage wise theres not much difference just pay attetion to the gear ratio mine with a 7.3 and starand trans 4x4 gets in the neigerhood of 16 to 18 depend on how u drive mine also has the 4.88 rears with 225/70r19.5
Old 10-18-2009, 09:10 AM
bfife's Avatar
bfife
bfife is offline
still plays with trucks
Check out my photo gallery. I took an 02 F550 flat bed and converted it to a pickup bed. several issues to deal with. the frame on the f550 is different from the cab back. its also 4 inches longer, hence the need for spacers and custom mounts. 550's have much bigger brake rotors 15 in frt 14 in in rear . rear axle is a Dana 135. not alot of wheel options, 19.5s are stock. engine, tranny, T/case are all the same.
Barney
Old 10-18-2009, 08:15 PM
dieselkid's Avatar
dieselkid
ok so theres not much rim options. there is a 4in gap between the bed and the cab? (if thats the case i could get 2 beds and get a shop/me to fuse them togeather and i get a lil bigger bed) but other then rims and custome bed theres noting to worry about. 18 mpg is wut i would like with 35in wheels.... u think i could get kmc to build me a custome set of rockstars to fit the f550?
Old 10-19-2009, 03:44 AM
bfife's Avatar
bfife
bfife is offline
Rickson truck makes wheels for the 550 in different widths. as far as someone making wheels for you, it only takes money, if you've got enough somebody will do it. remember the 550 comes with 4.88 gears, period. the only options are lower. I run a US Gear 2speed behind my 6 sp and the best mpg I can get is 14. but with those gears you won't have to regear for 35's.
Barney
Old 10-19-2009, 05:45 PM
bigfordmatt
well as far as the gap that would depend on the frame length and wheel base i had a 28 inch gap were i did add to it i will post some pics of it on here in my photo gallery
Old 10-20-2009, 10:50 PM
dieselkid's Avatar
dieselkid
did i read ur gally info right? pls correct me if im wrong, a 10ft bed ???? o.0 thats just epic
i need to do some more research, basid on the bed convertion and tires, im not liking the hole 19.5in rims. i want 16/17 with a normal lug pattern
renegade_75
07-13-2016 11:40 AM
New SD
1999 to 2016 Super Duty
12-14-2015 11:46 AM
fraser.cook
05-13-2014 07:49 PM
alex1985blue
07-31-2012 12:57 AM
rhodeman
22
06-21-2010 03:16 PM
Quick Reply: f500/550
