Ford Explorer 8.8 rear end - Ford Truck Enthusiasts Forums
Old 10-09-2009, 08:25 PM
abrauer abrauer is offline
abrauer is starting off with a positive reputation.
I am thinking about using a Ford Explorer rear end in my 52 F-1. Being that I am not building a power house for a motor and I know wher I can find one what do you need to get when you aquire one. Do you need to get all the leaf springs as well? The specs say its 59 in hub to hub and that is 2 inches shorter than the 9 inch I was going to use, what do you have to do to make it fit? Any help would be great.
Adam
Old 10-09-2009, 09:13 PM
Lakotas53's Avatar
Lakotas53 Lakotas53 is offline
Lakotas53 is starting off with a positive reputation.
My memory is not as good as it use to be, but if I remember correctly the
8.8 I put under my 53 was 59 1/2" from backing plate to backing plate. It fit perfect. I just got everything from brake drum to brake drum. Couldn't find one with disk brakes at the local pull a parts place. Almost a direct replacement. I had to flip the spring perches over and re weld them. I used the leaf springs from my 53 but I did use the u bolts that came with the 8.8. Oh yeah I had to weld the shock mounts onto the axle tubes too. Pics are in my gallery. Lakota
Old 10-09-2009, 10:54 PM
HD74's Avatar
HD74 HD74 is offline
HD74 is gaining momentum as a positive member of FTE.
Quote:
Adam
Why go thru the trouble with the 8.8 when you can get a 9 inch from a f-100 from 57 to 72 thats basicly a bolt in?
Old 10-09-2009, 11:02 PM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
I know nothing.
Old 10-09-2009, 11:12 PM
HD74's Avatar
Quote:
Originally Posted by havi View Post
Still have shock mount issues. Plus finding an Explorer 8.8 is easier than the older 9". So on, and so forth. Keep in mind the wheel lug pattern is different between the two. The disc brakes are the preferred on the 8.8, when folks do the swap, though.
My understanding that this is a direct bolt in if your mounting below the springs and I forgot that not everyone is keeping the stock frontend and would want smaller wheel bolt pattern.
Old 10-10-2009, 05:54 AM
Fifty4F100's Avatar
Fifty4F100 Fifty4F100 is offline
Fifty4F100 is gaining momentum as a positive member of FTE.Fifty4F100 is gaining momentum as a positive member of FTE.
I have an old Classic Truck's magazine (Aug. 2006) that has an article in it about the 9". Seems the 1st ones weren't that good at all. What you will find in a parts yard isn't anything close to the NASCAR 9"ers. I have a 9" from an old 57 I used to have in my 54. It leaks like crazy, so its probably cracked in the usual places. The 9" wasn't any good until '68. And then only on high performance car and heavy duty truck applications. So much for my free 9".
The reason I had the 9" laying around is because I used a 8.8 out of the donor Lincoln in my old 57. I did have to buy some spring perches from a local spring shop in Memphis and get some shock mounts from a parts yard. It had much bigger brakes and it moved the wheels out closer to the edge of the fenders. And it matched the front end I was using. I never got it running before I got rid of it to go after the 54, so I don't know if it was that much better.
Old 10-10-2009, 05:59 AM
norvillebob's Avatar
norvillebob norvillebob is offline
norvillebob is starting off with a positive reputation.
Quote:
Is that true? I looked in the gallery and it does looks awfully close. So if you wanted to drop the rear 4" and explorer 8.8 looks to be a bolt in.
bob
Old 10-10-2009, 07:07 AM
jaye's Avatar
jaye jaye is offline
jaye is starting off with a positive reputation.
I used the 8.8 however, I used the u-bolts and tie plates so I didn't have to weld shock brackets on, I did however, put new spring perches on the top. The pinion angle may not be correct for a bolt if it will with relocating the original perches
Old 10-10-2009, 08:55 AM
havi's Avatar
I know nothing.
Wheel offsets dcavan001 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 11-26-2016 12:21 PM
2008 f250 hubs strat875 Modular V8 (4.6L, 5.4L) 0 12-01-2015 10:26 PM
Built to tow RojoStar Aerostar 35 01-15-2015 01:32 PM
2002 Ford Explorer rear Bearing Press ORDER b07bruce Explorer, Sport Trac, Mountaineer & Aviator 3 11-01-2013 07:15 AM
1999 Ford Explorer rear end interchange Mike Rettinger Explorer, Sport Trac, Mountaineer & Aviator 1 04-07-2012 07:11 AM
Tags
1948, 2001, 53, 88, breaks, chevy, codes, end, explorer, f1, ford, rear, rearend, swap, swapping, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
