Weight in-bed for Winter Traction
#92
#94
#95
#98
I run ~600lbs in my s/c l/b 2wd. Four 2'x2'x4" concrete blocks at the front of the box. Well, 2 at the front and the other 2 right behind them. It helps keep some weight on the front for steering.
I also have a very good set of studded tires. I was plowing through 2-3' snow drifts at my work. I even had to park in a little over 2' of snow, but never got stuck. Only when the stuff gets wet and my diff starts pushing snow do I get stuck.
#99
Glad you liked it. Saw one the other day, can't remember it ( one of the many problems associated with old age ). Something about " Volkswagens " is all I remember. Should write yours down so I have them.
#100
on
1 Post
what we do in the sandhills area of nebraska: cut an inner-tube in half, so you have two "noodles". wire one end of each of them shut and back into a blowout, so they are already in the bed (they get HEAVY), and shovel em full of sand, wire the other end shut and put em over, just inside of, or right behind, the fenders in the bed. works wonders. im also a fan of regular sand bags, cinder blocks, old wheels and tires (currently using), snowmobiles, ATVs, and the occasional chebby truck (because a Ford, unlike chebbys, can actually take more than the recommended max payload without breaking, or even noticing).
#101
So, what exactly is a snow drift anyway? If they're three feet high, woldn't that damage your truck if you ran into it? How do you know it's not solid? Or do drifts not get solid..?
Thanks for your reply Bud
Thanks again to everyone. This thread has become very entertaining, keep up the friendly banter!
#102
A snow drift is what happens when the wind blows the loose snow around and it accumulates into a certain spot building it up. Sometimes they can be bad on the hyways but in general they are the worst on the less traveled roads.
They dont usually get hard packed unless the weather warms up then drops back to really cold. They are usually just soft snow, But just like anything use commonsense while winter driving. If it looks as though you might get stuck, just edge into it some back out of it so you know you can get out then try agaian taking on a little more, or you can shovel it out of the way.
I always opt for driving threw them as there are often more vehichles around to pull me out if i get stuck while at work.
Last winter we got just about 36" of snow in 36 hours. Hyways were shut down and they were travel at your own risk as the tow trucks or snow plow's would not travel out in that weather untill it stopped snowing.
Good luck and Hope this helps out a bit.
On a side note does your truck have a block heater on it? If not you may want to look at getting one if a white misserable cold winter is a new thing to you.
#103
on
1 Post
70FE250
24
12-08-2015 02:18 PM
CTC01
26
11-24-2015 07:23 PM
