2005 F150 Window Regulater???? HELP?!!?!? - Page 2 - Ford Truck Enthusiasts Forums
Old 11-04-2009, 06:15 PM
Mr Stacy A's Avatar
Mr Stacy A Mr Stacy A is offline
Mr Stacy A is starting off with a positive reputation.
Quote:
Originally Posted by vettdvr View Post
Save $$ don't spend the $$ on wood for the block,, use son in law
Oh. That's hillarious. Unfortunately I don't have a son-in-law (not old enough) but I do have a father-in-law that will help me.
I just got a call earlier today from the shop. It seems my Olympicare coverage expired at the first of October. They wanted $325 to fix. I said thanks but no thanks, I'll do it myself. Now where do I order from?
Old 11-04-2009, 07:29 PM
vettdvr's Avatar
vettdvr vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.vettdvr is gaining momentum as a positive member of FTE.
I ordered from Ed the parts guy supporter on this site. The 2005 rear door regulator was right at $100 delivered.
do a search for Ed the parts guy you will find him.
Old 11-05-2009, 10:18 AM
bgf1 bgf1 is offline
bgf1 is starting off with a positive reputation.
it's the window regulator. They cost @$130 at a parts shop- @$150 from a dealership. Not that big of a deal to replace yourself. May take 30 min to an hour, depending on how good you are at that sort of thing.
Old 11-05-2009, 10:23 AM
window regulator
Quote:
Originally Posted by lakeforkfisherman View Post
Welcome to the "Ford Window Regulators Suck" Club. I have had 3 replaced on my 2004 Screw. From what I understand, its a plastic piece on the regulator that breaks. Have to replace the whole thing. Good luck.
Yep- same truck- same thing- i have one that hasn't been replaced ....yet....
Old 11-05-2009, 12:12 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt Parts Guy Wyatt is offline
Former Vendor
Parts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud of
YOU GET A GREENIE FROM ME!
Ed
Old 11-05-2009, 03:41 PM
vettdvr's Avatar
Quote:
Ed
Always willing to help, after all you helped me out when I needed it.
I do have at least 4 Ford Trucks to keep going and going and going,, oops wrong commercial.!
Old 11-05-2009, 07:56 PM
Mr Stacy A's Avatar
I didn't realize Ed was the y2k parts guy. I've ordered a couple of parts in the past from his website. Fast service and the correct part. I'll be checking that out in a few days. I'm out of town right now.
Old 11-06-2009, 12:27 PM
Former Vendor
yeppers, I started on FTE a few years back here at Y2K and then went to that other dealer, they jacked me around so now I'm back here at Y2K.
Ed
Old 11-06-2009, 03:18 PM
HoutxF150 HoutxF150 is offline
HoutxF150 is starting off with a positive reputation.
none of my windows have fallen but I notice on the switch for the drivers side front window the switch seems like it gets stuck when trying to get the window to come up...goin down is fine when I want the window to come up I may have to hit the switch 2 3 or 4 times any ideas or is this a common problem?
Old 11-06-2009, 08:24 PM
92F1504x4351 92F1504x4351 is offline
92F1504x4351 is starting off with a positive reputation.
2005 Right Rear Window Cable Tangled
This afternoon, my right rear window quit working. I removed the door panel and the cable was all tangled up. I pushed the window up and used wooden tapered shims to wedge the window closed. Advance Auto has a rebuilt Cardone Window Lift Motor (42-3040)for $62. I'm not sure if this is what I need. I'll take it apart tomorrow. I read that someone had a repair procedure written. Has it been posted.
Thanks
Old 11-07-2009, 04:00 AM
svt2205 svt2205 is offline
svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.
Quote:
Very common problem. Do a little digging and you'll find a number of threads on this. But it's very easy to remove the switch. Then open it up and clean the contacts. This will improve things for a little while, but a new switch is in your future.
Ed, when I looked up the drivers door regulator on your site I didn't see it list different parts for different body configurations (super cab vs the others) what is the right part number to order for my 07 supercab? My window is getting slower by the day, so I'm thinking it's time to fix it.
Old 11-08-2009, 07:20 PM
Muddedprairie's Avatar
Muddedprairie Muddedprairie is offline
Muddedprairie is starting off with a positive reputation.
Well my FX4 pass side window reg is shot... the window comes up very slow and needs help... At that as well. Also my driver side window switch is messed up. My auto window down dose not work but it sure comes up pretty quick... think i need a new switch and or i have to take it out and clean the contacts.
Mark
  #28
Old 11-09-2009, 01:51 PM
Former Vendor
The online catalog is a little confusing.
here are the part numbers in most cases, but always order with vin to be sure.
REG and Crew cab RH FRONT 4L3Z1523200CA
LH FRONT 4L3Z1523201CA
supercab RH 4L3Z1823200CA
LH 4L3Z1823201CA
Crewcab rear RH 6L3Z1627000AA
LH 6L3Z1627001AA
Supercab rear RH 6L3Z1827000AA
LH 6L3Z1827000AA
shipping is $15 ea
Ed
  #29
Old 12-27-2009, 12:00 AM
turtletalk turtletalk is offline
turtletalk is starting off with a positive reputation.
does any one have pics reguarding this repair Im doing one tommorrow if i get enough info
  #30
Old 12-27-2009, 03:11 AM
dirtslmfan_25 dirtslmfan_25 is offline
dirtslmfan_25 is starting off with a positive reputation.
Don't be intimidated by this job, it's not that hard to do. I've only replaced the front's but the back can't be much different. Just take your time and you'll be fine. The only tool that might be out of the ordinary that you will need is a torx screwdriver (can't remember the size), a torx socket is too large to get into the opening. Save yourself some money!
idiot lights<the altanater > bert cook 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 10-06-2014 11:57 AM
Power Windows Loafer 1987 - 1996 F150 & Larger F-Series Trucks 3 08-04-2014 10:17 PM
2001 E-450 V10 problems Davesavet46 Modular V10 (6.8l) 5 10-17-2013 01:45 PM
What's the cause?? JReinert 6.0L Power Stroke Diesel 5 04-04-2008 08:05 PM
Fires only after I release starter HenryFord Electrical Systems/Wiring 15 06-23-2004 10:09 PM
Tags
05, 150, 2004, 2005, door, f150, fell, ford, instulation, motor, regulator, repair, replace, replacement, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
