You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Did my first batch the other day and got about 4% unreacted with the methanol test.
Did my second batch last night and got about 2% unreacted.
So I have been doing more reading and I think my KOH base might be too low, getting conflicting #'s
The recipe I was following suggested 5.0 base + titration. The oil I am using titrates very low @ 2.0
25% methanol
This is a 4 gallon batch, with paint stir agitation processed for 60 minutes kept between 120-135F.
First batch I used 7.0/liter.
Second batch I used 8.0/liter.
So I have read more and find some other #'s for base using koh. I see 7.0 and 9.0/liter.
Looking for complete reaction, but not too much soap(read, easy wash)
25% methanol
Any advice appreciated.
5.0/ltr is way to low. Base for KOH at 100% is 7.8/ltr + titration.
The KOH that I get is 90%, so I use a base of 8.2/ltr + titration.
If your KOH is 90% you should have used 8.2 + 2 for a final figure of 10.2/ltr.
120 deg is to cold, and would require longer mix time.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
I was trying to keep it between 130-140 but I need to watch it a little closer. It was up around 130 for most of the time, but I know it was down in the 120's at one point.
going to try another batch here in a bit. Not sure on the potency of my KOH, got it from braintan.com it doesn't specify the potency. Probably should figure on it being 90%
I will use your figures and see how it works out.
I am getting close to that figure with trial and error anyway.
Don pretty much has it covered. I am curious as to how you are determining that amount of unreacted bio out of 3ml.
You may already know this, but if you don't, your 3/27 test needs to be held at 68f for 20 minutes. I usually control temp with a water bath if ambient temps aren't at 68f. Higher temps can give a false pass, whereas colder temps can give a false fail.
I was using 25ml of bio and 225ml of meth. Basically the same just larger scale. with 25ml, every 1ml of oil=4%
I wasn't paying much attention to temp. My last batch last night using fab's #'s looked pretty bad with the 3/27 test but my methanol was probably 50-55 degrees.
Theres so much bad info out there its scary. I wonder how many people just follow directions and never test and just run it.
Thanks guys. One more thing learned. I am sure I am not done with the questions.
Still had problems with my next few batches, figured out I wasn't processing long enough. Bumped up my time from 60 minutes to 90 minutes and it took care of it.
Got to get a larger supply of KOH then it will be time to play with Methanol recovery.
