Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Canadian National Chapter > Alberta Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Alberta Chapter Join Chapter, Leader: Hallworth
  #1 (permalink)
Old 01-12-2003, 09:40 AM
Dave 69_88 F Series Dave 69_88 F Series is offline
Garage is empty, add now
Dave 69_88 F Series is starting off with a positive reputation.
Hi
Just noticed this chapter and thought Id say Hi. Iam from the Fraser Valley. Iam curently parting out a 69 F250 and trying to Put the 390 into my 88 F150 4X4.
Bye for now
Dave
  #2 (permalink)
Old 01-12-2003, 01:07 PM
sparky's Avatar
sparky sparky is offline
sparky is starting off with a positive reputation.
Hi
Hi Dave;
I am from the Comox Valley. I am currently in the preliminary stages of transplanting a 69 F250 body onto a 73 F250 frame. Right now I am stripping the 73 down to the frame. Too bad you are on the other side of the BC Ferry System as you might have some parts I may need
Neat project you are working on. Just wondering how the 390 is fitting into the 88 frame? A litle fabricating must be involved I mean those engine towers werent made for a 88. I assume you just bolted everything together, engine tranny and mounts. Set it in place where you wanted it to sit. Then just welded/bolted the towers to the frame, adding spacers as necessary. Or is there a better way? Or does it actually fit like factory?
Talk to you later.
Sparky
__________________
Sparky
Junk is something you've kept for years
and throw away three weeks before you need it.
  #3 (permalink)
Old 01-12-2003, 06:07 PM
Hi
Well havent got that far yet trying to find out just what problems Iam going to have. I have a 3 inch body lift in the 88 so that should help. I was hoping that all I had to do was bolt the 69 frame engine mounts onto the 88 frame in the same spot. But it sounds like its more complicated then that. Took me awhile to get some answers to find out how to mate the 390 tranny to my 1345 transfer case just have to change the out put shafts and the adapter. Any advice on what Iam facing would be a big help.
Thanks
Dave
  #4 (permalink)
Old 01-12-2003, 07:46 PM
sparky's Avatar
Hi
Hopefully they will bolt right on the 88's frame....but I have some doubts the frames changed quite a bit after 79 and the last year of the FE was 76.
But you never know til you try Good luck.
Sparky
__________________
Sparky
  #5 (permalink)
Old 01-12-2003, 09:06 PM
Hi
Thanks someone did say that the oil filter will hit in the 88 frame wonder if there is a kit for relocating the filter.
Dave
  #6 (permalink)
Old 01-12-2003, 09:24 PM
sparky's Avatar
Hi
There should be one around somewhere. They are called remote oil filters, in case you dont know what they are called
Try some of the online sites Wrenchead, jcwhitney just add ".com" I do not know if motorhaven sells them or not.
Sparky
__________________
Sparky
  #7 (permalink)
Old 01-13-2003, 12:52 AM
merc460 merc460 is offline
merc460 is starting off with a positive reputation.
Hi
Yes there is a block adapter for the 390 It will remote mount the oil filter It's made by trans'adapt you can get it at lordco. Eric
__________________
Eric
  #8 (permalink)
Old 01-13-2003, 09:32 AM
Hi
Great thank you.
  #9 (permalink)
Old 01-15-2003, 01:47 AM
Hi
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
