my 84 bronco (pics) - Page 3 - Ford Truck Enthusiasts Forums
Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
my 84 bronco (pics)
  #31
Old 02-26-2012, 08:28 AM
88dually 88dually is offline
88dually is gaining momentum as a positive member of FTE.
any updates ?
  #32
Old 02-28-2012, 12:18 AM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
unfortunately not much, other than sanding on some panels and discovering that all the body mounts are shot (which is why the couple of times i have tried bolting the panels on that they wouldn't fit right, look at the pic with the red clip on it while still outside, and look at the gap on the pass side)
about a month ago i got a job in colorado, so I am about 150 miles away from it, and i don't have a chance to go up and work more on it until next weekend, but when i do I intend to either get it fired up, or get the body mounts under it.
  #33
Old 02-28-2012, 05:53 AM
Keep up the good work
  #34
Old 06-03-2012, 03:23 AM
not much to update, the shop got overridden with pigeons, so i spent most of last weekend getting rid of them, and then using a half a bottle of simple green to get all their... droppings cleaned up.
i did however get my dual range pulled out of the parts truck, needs a little clean up still, but here you go:
  #35
Old 08-02-2012, 12:30 AM
Andrew James Andrew James is offline
Andrew James is starting off with a positive reputation.
Updates???
  #36
Old 08-02-2012, 01:20 AM
not really unfortunatly, after moving its 150 miles away and I can only get to it every now and then, i last worked on it about 2 weeks ago, but it was all cleaning and pulling seats and carpet to get to the body bolts as part of replacing the body mounts.
Really wish i could find a cheap garage space to rent around here... although I do assure you that i am not giving up, not by a long shot!
  #37
Old 02-05-2013, 11:00 AM
jthorngate3's Avatar
jthorngate3 jthorngate3 is offline
jthorngate3 has much to be proud ofjthorngate3 has much to be proud ofjthorngate3 has much to be proud ofjthorngate3 has much to be proud ofjthorngate3 has much to be proud ofjthorngate3 has much to be proud ofjthorngate3 has much to be proud ofjthorngate3 has much to be proud of
This is a really awesome project! Just came across it from the link in your sig on the CO thread. A lot of the things you did were things I had thought about, but knew I was not really capable of myself. Can't wait to see you driving that thing.
  #38
Old 03-03-2013, 10:37 AM
smill24v smill24v is offline
smill24v is starting off with a positive reputation.
wow everything looks good man keep it up!
  #39
Old 04-10-2014, 02:21 AM
Wow, haven't updated this in a while, but then again I have only been able to work on it sporadically.
I got the body mounts under it over the summer, and finally my fenders will fit without 1" gaps! and talk about a pain to replace...
finally bolted in the starter and exhaust (all two feet of it) I'm hoping that the engine doesn't rock enough for it to make contact with the frame.
I'm also at a bit of a dilemma, and I cant decide where i should mount the connector for the megasquirts harness to pass through the firewall, its a connector built for going through firewalls, and it uses weather-pack terminals, and will require cutting a 2" hole.
here are some of the locations I have been considering:
right now i'm thinking more along the lines of #3, it'll be convenient to wire on the engine side, but up high enough to stay out of dirt /water, and be aesthetically pleasing. provided that it will work on the other side of the firewall as well.
I have been thinking I'll mount the megasquirt in the dash fairly high, and run a custom "DLC" connector for tuning.
any better ideas?
  #40
Old 04-10-2014, 02:23 AM
oh and as far as the carb goes, I am planning on using it to get a baseline so i can compare the megasquirt to it later.
  #41
Old 04-29-2014, 07:34 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250 Rusty_Old_F250 is offline
Rusty_Old_F250 is gaining momentum as a positive member of FTE.Rusty_Old_F250 is gaining momentum as a positive member of FTE.
What brand is the dual range box? Is it an over or an under?
Sam
  #42
Old 05-05-2014, 11:48 PM
it was made by US Gear, and from what I understand was part of doug nash.
I'm 95% sure this one is an under/direct. but they could be had in any combination.
Superduty bed swap pictorial BioBurner 1999 to 2016 Super Duty 49 12-12-2016 02:57 PM
lowering the front end vintage tin 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 01-06-2014 08:47 PM
My '76 F-100 Project spiritof76 1973 - 1979 F-100 & Larger F-Series Trucks 19 11-18-2013 06:59 PM
9" Axle Swap How To / Project Pictures - PIC HEAVY RAY1986F150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 09-23-2012 01:49 PM
Dents still serving in public safety! tbear853 1973 - 1979 F-100 & Larger F-Series Trucks 7 08-03-2011 10:33 PM
Tags
84, bronco, conversion, crawler, crawlers, f250, ford, full, megasquirt, pics, pictures, project, rock, size, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
