my 84 bronco (pics) - Page 2 - Ford Truck Enthusiasts Forums
Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
my 84 bronco (pics)
Old 05-26-2010, 07:03 AM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
Quote:
Originally Posted by khadma View Post
Broncos are the best. I have a small project too. Is the chassis saver paint good for axle housings too? Is there a link for the company that supplies the paint?
True that, I have been following your buildup, as i might steal your idea of using a jumpseat.
the chassis paint is called Chassis Saver
Paint Over Rust to Stop Rust Permanently With Chassis Saver Truck & Auto Underbody Coating
-I love the stuff, its tough as nails, can be brushed or sprayed on (I brushed mine on, It still flows out smooth) I bought a quart and have been sharing with friends and still have hardly used any.
Old 05-26-2010, 04:01 PM
khadma's Avatar
khadma khadma is offline
Carpenter Local 745
khadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud of
I wish the Chassis Saver paint came in different colors.
I wanted to paint my axle housings red.
One more thing, are all frames just painted with paint or is there some kind
of undercoat on them from the factory?
Old 05-26-2010, 08:06 PM
all of them that i have had has just been (or was suppossed to be) paint. alot of undercoating done has been aftermarket.
I hate the stuff GM puts on thier truck frames, i saw a 2500 almost fall off a two post due to that slimy stuff...
Old 06-13-2010, 02:24 AM
it has been a while so i dug through some photos and found some to post. the first two are from when i was making a set of white faced gauges. the second is the beginning of my modified exhaust since i don't really like the design of the walker pipe, this should give the exhaust a smoother transition.
Old 09-30-2010, 08:22 PM
well I am back home, but haven't gotten much done other than a handful of little items, but more should be on the way soon.
radiator support was painted with chassis saver and then sprayed down with a coat of black enamel so it doesn't fade I also painted the inside of the fenders
the next step in the custom exhaust I am building, although now I need to get a 45 for it as this pipe almost reaches the ground! I have been thinking about running 3" all the way back, but haven't made up my mind yet.
Old 10-06-2010, 12:10 PM
TheGhost's Avatar
TheGhost TheGhost is offline
TheGhost is starting off with a positive reputation.
Nice project. Seems to be coming along pretty quick as well. Keep up the good work.
Old 09-21-2011, 01:44 AM
Quote:
Originally Posted by muscletruck7379 View Post
finally got a little time in the busy harvest season to post some pics that i took over the past couple of months of my bronco
i worked an entire summer for my dad when i was 16 and he bought me this bronco and gave me a rebuilt 302 for it. i eventually traded it off, but when i got the chance to get it back i jumped on it, even though it is in nowhere near the shape it once was.
just getting her home:
IMG]http://i19.photobucket.com/albums/b159/mattbox87/automotive/DSCI0004.jpg[/IMG]
front clip off:
notice the piece of strap that is sticking up? it was being used to support the battery tray!
i got tired of it looking so naked so i dropped the clip off the 84 f150 that i got for it on so i could have a change in the look, temporarily:
the 300-6 that im working on, sans intake and accessories:
thats all for now, as soon as i have some more free time (around the end of the month) i will post some newer, updated pics.
Repaired links for the photo's from the first post, i'm gonna ask the mod if i can get this repaired on the first post
Old 09-21-2011, 02:18 AM
some more old pictures to kinda help keep the thread afloat. I should be home in december!
picture of a picture(note how the one side is kinda skewed) of the bronco back in about 2003 when i first bought the bronco:
front frame rails while coating with chassis saver
working on the exhaust:
pulling the suspension out of the 86. the 4" lift went to a buddy, i'm hanging onto the front beams to do my cut and turn. don't do this at home children!
I sold the drivetrain, and scrapped the remaining rusted hull and came out with 400 bucks more than i had into it! i hate sending detroit iron to its doom, but sometimes its for the best (rusted past saving and no title in sight)
Old 09-21-2011, 02:44 AM
Deaver 5.5" coils i picked up used for 75 bucks. these are considered the flexiest and smoothest riding coils available.
I am thinking that i will build some coil buckets that are 2-3 inches taller than stock, then cut some spacers on a lathe (or build a jackshaft arrangement) until i get the height I want.
i'll build my own radius arms and i intend to run iniballs in bothe the radius arms and the beam pivots.
I am on the lookout for a good deal on some long 5100 bilstiens, if it comes time for them before i find a deal/discount, i'll just go ahead and buy them
I will keep the front sway bar but will most likely ditch the one on back
Old 10-14-2011, 08:57 PM
new bilsteins are in, 5125 monotubes with a 14" stroke. should go nicely with the deavers.
new all aluminum 2 core showed up as well, so here is a sneak peak:
Old 12-28-2011, 11:29 PM
Finally back home! should be doing actual updates now!
for now i need to do some dusting:
here is something I tossed on this evening:
its the relay bracket off an early 90's fwd olds, has 4 spots for relays (I only have two right now) and a neat little power distribution box with its own cover.
Old 12-29-2011, 05:01 PM
last night i painted the heater box and made it look pretty again, kinda wish i had medium gloss instead of high gloss paint though.
and one with the fender on.
afterwards I dived into fixing the mount for the hood hinge:
doesn't exactly line up, im gonna see if the cowl will cover the variation, if not, im not sure what im gonna do with it.
I also started looking as to why whenever I place the right front fender in place I cant get it set so the the gaps look close. ended up laying on the floor with a tape measure and found out the body mounts on the passenger side are 3/8" shorter than the drivers side
looks like I'll be getting new body mounts for it. lmc has a 20 piece poly mount kit thats less than what buying the rubber individually would be. anybody have any experience with poly body mounts?
  #28
Old 01-08-2012, 12:00 PM
lukewdavison lukewdavison is offline
lukewdavison is starting off with a positive reputation.
cant see pics on the first page first post
  #29
Old 01-10-2012, 09:15 PM
I moved them on my photobucket account, which broke the links. I couldn't edit that first post so I reposted them. They are the pics in post #22
  #30
Old 01-11-2012, 11:16 PM
ended up working on the 88 the other night, but while I was doing that, my best friend ryan flexed his welding skill on the firewall:
Superduty bed swap pictorial BioBurner 1999 to 2016 Super Duty 49 12-12-2016 02:57 PM
lowering the front end vintage tin 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 01-06-2014 08:47 PM
My '76 F-100 Project spiritof76 1973 - 1979 F-100 & Larger F-Series Trucks 19 11-18-2013 06:59 PM
9" Axle Swap How To / Project Pictures - PIC HEAVY RAY1986F150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 09-23-2012 01:49 PM
intercooler all done, final product pics rideracelivemx7 1994.5 - 1997 7.3L Power Stroke Diesel 35 06-04-2010 11:34 AM
Tags
84, bronco, conversion, crawler, crawlers, f250, ford, full, megasquirt, pics, pictures, project, rock, size, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
