Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-09-2009, 12:28 AM
Shoestring's Avatar
Shoestring Shoestring is offline
Shoestring is starting off with a positive reputation.
2005 4.6 2 valve in a 68 F100
Hello all I am new to this forum of the Modular Ford V8s. I am trying a project of putting a newer motor in an older truck. I have all wiring harnesses inside the engine compartment including the stock computer. I am however new to making a computer driven motor fire up. I know I could buy an after market computer and wiring harness but would like to save that money for other things on this project. I have a wiring diagram on order for this motor but would like to know what sensors does this motor need to have to opperate properly and what can I omit? Also any other tips you guys might have on how to make this baby fire up would be helpfull.
SS
  #2 (permalink)
Old 10-09-2009, 06:24 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of
Well, these require pretty much all of the sensors to run properly. The PCM uses inputs from all of them. You do have the instrument cluster too don't you? I'm pretty sure it is required to release the PATS system and allow the PCM to let the engine run.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #3 (permalink)
Old 10-09-2009, 08:21 PM
Shoestring's Avatar
Quote:
Originally Posted by LxMan1 View Post
Well, these require pretty much all od the sensors to run properly. The PCM uses inputs from all of them. You do have the instrument cluster too don't you? I'm pretty sure it is required to release the PATS system and allow the PCM to let the engine run.
Hmm I have access to the cluster but I did not pull the system from the car. What is the PATS system?
  #4 (permalink)
Old 10-10-2009, 12:57 PM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
2005 Ford F-250
Johnny Langton has a good reputation on FTE. Johnny Langton has a good reputation on FTE.
Quote:
PATS
Passive
Anti
Theft
System
It marries the cluster, key, and the PCM to each other. If all three do not match, then the PCM will not allow the engine to start. Aftermarket tuning can disable this "feature", allowing startup without the original cluster or key being present.
JL
__________________
1997 Thunderbird LX 4.6L/4R70W
12.16@111.78
1998 F150 Supercab 4.6L/4R70W-Gone,sold to Dad.
2005 F250 Crewcab
3V V10/Torqshift 4.10LS
2001 Navigator
WANTED: OEM cat-back Exhaust from 2005-2007 5.4L or 6.8L Superduty
  #5 (permalink)
Old 10-10-2009, 06:51 PM
Shoestring's Avatar
Quote:
Originally Posted by Johnny Langton View Post
PATS
Passive
Anti
Theft
System
JL
Had not thought about the need for a tuning device prior to being able to start the motor. What tuners work best with these motors or does it matter? Are these chips or a programmer that you have to purchase?
  #6 (permalink)
Old 10-10-2009, 06:55 PM
Shoestring's Avatar
double post
  #7 (permalink)
Old 10-10-2009, 08:01 PM
2005 Ford F-250
I'd suggest finding a vendor that can make a custom program for what you're doing. Are you using the trans from the donor vehicle? There are many things that'll need to be accounted for in this application,and there are many vendors that can get you lined out on the proper methods of powertrain control in this type of application.
I see you're in Texas by your profile-whereabouts are you at?
JL
__________________
12.16@111.78
2005 F250 Crewcab
2001 Navigator
  #8 (permalink)
Old 10-10-2009, 08:58 PM
Shoestring's Avatar
I am in Amarillo. So visiting a custom programmer could fix what problems I might run into? Yes I am using or plan on using the donor vehicle transmission. It is supposed to be a good one.
  #9 (permalink)
Old 10-11-2009, 12:55 AM
2005 Ford F-250
A custom program will fix most of the issues in the PCM,but you'll still need to do some wiring,etc....I'll see who I know of that's reliable and close to your location if you'd like,and get you their contact info.
JL
__________________
12.16@111.78
2005 F250 Crewcab
2001 Navigator
  #10 (permalink)
Old 10-11-2009, 06:33 PM
Shoestring's Avatar
JL
If you could that would be helpfull. Wiring will not be bad if I have a good wiring diagram to follow. I have one in the mail so I should be good to go when I get it.
  #11 (permalink)
Old 11-06-2009, 07:50 PM
Rusty 63 Rusty 63 is offline
Rusty 63 is starting off with a positive reputation.
I'm new here & I'm right behind you! I was about to buy a wrecked cruiser at auction today, but let it go because after spending hours searching the net for info on getting the 4.6 2v to run in the truck, I was left thinking it was going to cost over $1200 bucks - and I still had to pull the entire harness out & send it to them (doesn't sound like much fun in a twisted wreck!). I should've checked here first! Have you had any luck yet?
  #12 (permalink)
Old 11-09-2009, 06:31 PM
Shoestring's Avatar
Quote:
All is good as you can see so far except lots of body work. The thing that is holding me back right now is the fuel delivery system. I am trying to figure out how or what I need to do to get fuel to the engine. Since I am using a stock computer I dont know if I can use after market fuel pumps and such. I have the fuel pump module that tells the fuel pump how much pressure to put on the line but I dont know if I have to use the original pump or go with an after market external pump.
SS
  #13 (permalink)
Old 11-09-2009, 06:36 PM
Shoestring's Avatar
Have you guys and gals seen this truck being built and posted by Classic Trucks Magazine? A link to it is here. It is pretty close to what I am doing except they are using after market harness and computer with tuner. I am wondering how they did the fuel system and if there is a link to that part of the build. I have looked and have not found it. They are pretty good on other parts of the story but have left the fuel delivery part out.
SS
Tags
1954 , 2005 , 46 , diagram , f100 , f250 , ford , pcm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
