1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
How much can it haul in the bed??
  #31
Old 10-10-2009, 11:38 PM
mstiles19's Avatar
mstiles19
mstiles19 is offline
Originally Posted by 74baja
3 Tons? Like 6,000#?!
haha yes sir
as previously stated these trucks (although not legally) can handle lots of weight. Last time i got hay i set a new personal record for my truck of 22,300 pounds total weight with truck and trailer. We also had the cummins dodge with us with another trailer which weighed out to about 21,000 pounds. My truck pulled the weight alot better than the dodge!
  #32
Old 10-10-2009, 11:41 PM
orng1's Avatar
orng1
orng1 is offline
I believe it, that's why nothing but E load range tires on these trucks. How far did you go with that in the bed?
  #33
Old 10-10-2009, 11:49 PM
mstiles19's Avatar
mstiles19
20 minute drive. the guy loading me up was laughing when he was dumping all the stone in cause i just told him to keep it pouring haha
  #34
Old 10-11-2009, 05:23 AM
TexasRebel's Avatar
TexasRebel
TexasRebel is offline
legally, any of these trucks can haul 26,000# minus curb weight when you're talking about truck & trailer with a class C license... they can actually do it too...
as far as cargo in the bed... you might not mind a ticket for being overweight, but I'm going to at least try to talk you out of exceeding your GVWR... It is very true that a 5.4L F250 can legally haul more without a trailer than a PSD F250... but you knew that when you bought it...
  #35
Old 10-11-2009, 09:41 AM
pbr man's Avatar
pbr man
pbr man is offline
Originally Posted by mstiles19
haha yes sir
I do this every time I haul hay. 7,800 pound truck, 3,500 pound trailer, 13,000 pounds of hay=24,300 pounds. A good trailer, with good brakes, loaded evenly handles the loads just fine. My truck is licensed for 26,000 gvw and as long as I keep the axle weights in check on the truck there is no problem from the DOT with hauling that much.
What pleased me the most was I average between 11.5 and 12.2 mpg when hauling that much.
  #36
Old 10-11-2009, 10:36 AM
Ace!'s Avatar
Ace!
Ace! is offline
That's interesting putting that much rock in the bed and have it all fit. What is your set up or did you exceed your tire ratings, your axle ratings and your GVWR?
  #37
Old 10-11-2009, 11:30 AM
bill11012's Avatar
bill11012
bill11012 is offline
Modular motor junkie
I get that empty with my V10, are you sure?
  #38
Old 10-11-2009, 12:02 PM
Workin4ALivin's Avatar
Workin4ALivin
Workin4ALivin is offline
He has a 7.3 PSD empty for him is probably 18+
  #39
Old 10-11-2009, 12:05 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
My 08 PSD 4x2 Dually has a GVWR of 13000, and a load capacity rating of 4839lbs. (4.10 rear axle)
Sam
  #40
Old 10-11-2009, 12:24 PM
bill11012's Avatar
bill11012
your right, I got him confused with another guy with a 5.4.
  #41
Old 10-11-2009, 01:31 PM
74baja's Avatar
74baja
74baja is offline
I don't know... I'm not worried about the suspension or tires nearly as much as I would be about the brakes... getting that much moving is one thing, stopping it in a hurry is very different.
  #42
Old 10-11-2009, 01:36 PM
jake00's Avatar
jake00
jake00 is offline
FTE is my crack
I've hauled about 3500 lbs of stone for a friend with no problems
  #43
Old 10-11-2009, 02:04 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
avoiding the 'hurry' part is best advice.
Sam
  #44
Old 10-11-2009, 03:00 PM
mstiles19's Avatar
mstiles19
i get 15 mpg empty with stock size tires and with my 35s i get 13.5 mpg empty. When ever i haul long distances i put my stock tires on and i got 12-13 mpg towing a two horse trailer with two horses and loaded down with all sorts of gear and water all the way to Vermont.
  #45
Old 10-11-2009, 03:09 PM
mstiles19's Avatar
mstiles19
exactly haha when you work a farm you get used to towing or driving things that most people wouldn't even attempt. Listen to the song international harvestor haha chug a lug a luggin' 5 miles an hour. its all about taking it slow and knowing what may be ahead of you and speeding up from behind you.
Quick Reply: How much can it haul in the bed??
