Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #31 (permalink)
Old 10-10-2009, 11:38 PM
mstiles19's Avatar
mstiles19 mstiles19 is offline
Garage is empty, add now
mstiles19 is starting off with a positive reputation.
Quote:
Originally Posted by 74baja View Post
3 Tons? Like 6,000#?!
haha yes sir
as previously stated these trucks (although not legally) can handle lots of weight. Last time i got hay i set a new personal record for my truck of 22,300 pounds total weight with truck and trailer. We also had the cummins dodge with us with another trailer which weighed out to about 21,000 pounds. My truck pulled the weight alot better than the dodge!
__________________
Matt - 2004 F250 - Extended Cab, Longbed, 6.0 Powerstroke, Manual Trans, 4 Inch turbo back exhaust, EGR Delete, Bypass oil filter, Coolant Filter, Cat EC1 coolant, Fuel pressure/Boost/Pyro Gauges, Scan Gauge II, Atlas 40 FICM Tune, Gearhead Automotive Tuning, B&W Hitch
  #32 (permalink)
Old 10-10-2009, 11:41 PM
orng1's Avatar
orng1 orng1 is offline
orng1 has a good reputation on FTE.orng1 has a good reputation on FTE.orng1 has a good reputation on FTE.
I believe it, that's why nothing but E load range tires on these trucks. How far did you go with that in the bed?
__________________
00 F250 5.4L K&N stock box folter, 257k miles.
01 F250 7.3L DP Tuner, Airaid intake, Magnaflow 4" turbo back, 88k miles. Bob
<img src="<a href=http://api.photoshop.com/home_e202e8e80efb4a1696c4980e2d094cf5/adobe-px-assets/c71a8ac8ad5f4072a1981a2a389f6f04 target=_blank>http://api.photoshop.com/home_e202e8...981a2a389f6f04</a>" width="450" height="150"/>
  #33 (permalink)
Old 10-10-2009, 11:49 PM
mstiles19's Avatar
20 minute drive. the guy loading me up was laughing when he was dumping all the stone in cause i just told him to keep it pouring haha
__________________
  #34 (permalink)
Old 10-11-2009, 05:23 AM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
2008 Ford F-250
TexasRebel has a very good reputation on FTE.TexasRebel has a very good reputation on FTE.TexasRebel has a very good reputation on FTE.
legally, any of these trucks can haul 26,000# minus curb weight when you're talking about truck & trailer with a class C license... they can actually do it too...
as far as cargo in the bed... you might not mind a ticket for being overweight, but I'm going to at least try to talk you out of exceeding your GVWR... It is very true that a 5.4L F250 can legally haul more without a trailer than a PSD F250... but you knew that when you bought it...
__________________
2008 F-250 XL 5.4L Reg. Cab 4x2 6-spd 4.10 w/B&W "Turnoverball"
OE Options installed: TowCommand Brake controller, Upgraded to 4 spkr. Single CD/AM/FM w/AUX from 2 spkr. AM/FM, cab clearance lights, Fog Lights, Cruise Control, Redundant Audio Controls.
  #35 (permalink)
Old 10-11-2009, 09:41 AM
pbr man pbr man is offline
pbr man is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by mstiles19 View Post
haha yes sir
I do this every time I haul hay. 7,800 pound truck, 3,500 pound trailer, 13,000 pounds of hay=24,300 pounds. A good trailer, with good brakes, loaded evenly handles the loads just fine. My truck is licensed for 26,000 gvw and as long as I keep the axle weights in check on the truck there is no problem from the DOT with hauling that much.
What pleased me the most was I average between 11.5 and 12.2 mpg when hauling that much.
__________________
Eric 1999 F350 4x4 Super Duty, Crew Cab Long Bed,7.3 Diesel, 6 speed, 4'' Diamond Eye exhaust, 4040 Aeroturbine, Dipricol Optix-boost and pyrometer, AIH delete, Hutch and harpoon, Tuff Country Add a Leaf
Democracy is two wolves and a lamb voting on what to have for dinner-liberty is a well armed lamb contesting the vote" Thomas Jefferson
  #36 (permalink)
Old 10-11-2009, 10:36 AM
Ace!'s Avatar
Ace! Ace! is offline
Ace! has a good reputation on FTE.Ace! has a good reputation on FTE.Ace! has a good reputation on FTE.
That's interesting putting that much rock in the bed and have it all fit. What is your set up or did you exceed your tire ratings, your axle ratings and your GVWR?
__________________
2005 F250 V10, CC, SB, 4x4, 4.30 axle ratio
1994 Exploder XLT, 4x4, auto trans and Pioneer cd player
"Deserve's got nothing to do with it"
TripleA RV in Medford, OR SUCKS
  #37 (permalink)
Old 10-11-2009, 11:30 AM
bill11012's Avatar
bill11012 bill11012 is offline
Modular motor junkie
bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.
I get that empty with my V10, are you sure?
__________________
My V10 will out pull your PSD any day of the week,
If its close to stock and of the same age as my V10.
My IDI can't out pull anything.
  #38 (permalink)
Old 10-11-2009, 12:02 PM
Workin4ALivin Workin4ALivin is offline
Workin4ALivin is starting off with a positive reputation.
Quote:
He has a 7.3 PSD empty for him is probably 18+
__________________
2005 F350 SRW CC 4x4 6.0L Torqshift
  #39 (permalink)
Old 10-11-2009, 12:05 PM
sdetweil's Avatar
sdetweil sdetweil is offline
1955 Ford F-100
My Garage
sdetweil has a great reputation on FTE.sdetweil has a great reputation on FTE.sdetweil has a great reputation on FTE.sdetweil has a great reputation on FTE.
My 08 PSD 4x2 Dually has a GVWR of 13000, and a load capacity rating of 4839lbs. (4.10 rear axle)
Sam
__________________
55 F100 460/c6, 3.55ls - 436 hp, 489 tq
12 F250 4x4, SRW, 3.31, CC, SB 400 hp, 800 tq
08 F350 4x2, DRW, 4.10ls, CC, LB - sold
  #40 (permalink)
Old 10-11-2009, 12:24 PM
bill11012's Avatar
Quote:
your right, I got him confused with another guy with a 5.4.
__________________
  #41 (permalink)
Old 10-11-2009, 01:31 PM
74baja's Avatar
74baja 74baja is offline
2001 Ford F-350
74baja is starting off with a positive reputation.
I don't know... I'm not worried about the suspension or tires nearly as much as I would be about the brakes... getting that much moving is one thing, stopping it in a hurry is very different.
__________________
Jack
2001 F350 7.3 PSD SRW SC SB Limited Slip 3.73's 4x4 Off-Road Auto. 4" Magnaflow, 6637, Transgo HD-2, Autometer 3 gauge pod w/ pyro, Trans. temp. and boost, PHP PHOENIX (40T, 80DD, 100P, SS), GPR LED, FRx, HPx, Foil Delete, $.50, Truxport bed cover, Hide-A-Ball Gooseneck Hitch...
  #42 (permalink)
Old 10-11-2009, 01:36 PM
jake00's Avatar
jake00 jake00 is offline
FTE is my crack
2007 Ford Expedition
jake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant future
I've hauled about 3500 lbs of stone for a friend with no problems
__________________
Past rides
06 F250 CC v10 4x4 Lariat bought 5/08 for 20k sold 10/10 for 20K.
RIP BIG GREEN owned her from 08.17.04 - 05.10.08
  #43 (permalink)
Old 10-11-2009, 02:04 PM
sdetweil's Avatar
1955 Ford F-100
My Garage
avoiding the 'hurry' part is best advice.
Sam
__________________
  #44 (permalink)
Old 10-11-2009, 03:00 PM
mstiles19's Avatar
i get 15 mpg empty with stock size tires and with my 35s i get 13.5 mpg empty. When ever i haul long distances i put my stock tires on and i got 12-13 mpg towing a two horse trailer with two horses and loaded down with all sorts of gear and water all the way to Vermont.
__________________
  #45 (permalink)
Old 10-11-2009, 03:09 PM
mstiles19's Avatar
Quote:
exactly haha when you work a farm you get used to towing or driving things that most people wouldn't even attempt. Listen to the song international harvestor haha chug a lug a luggin' 5 miles an hour. its all about taking it slow and knowing what may be ahead of you and speeding up from behind you.
__________________
Tags
2004, 99, bed, carry, duty, f150, f250, f350, ford, haul, heavy, how, put, super, truck, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
