Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #91 (permalink)
Old 11-01-2009, 07:23 PM
FLATFORD1976's Avatar
FLATFORD1976 FLATFORD1976 is offline
FLATFORD1976 is starting off with a positive reputation.
If I am not mistaken the cowl vents allow fresh air in to the truck. If i need fresh air I'll roll the window down lol..
Has anyone noticed that the tranny tunnels on these trucks is not only huge but it is offset to the passengers side. Well I fixed mine today. I posted earlier that I am dropping my floors down on either side to drop my seating height. when I started the passengers side today I also cut about 4" of the tunnel narrowing it giving myself the same amount of room on both sides. The measurement from the kick panel to the curve in the tunnel on the drivers side was 27" and the passengers side was 22 and 1/2. Thats a huge difference (to me anyway). Now they are both about 27". Looks alot better too. Here's a couple of pics i am not done with it but you can see how much of a difference it made.
First this is the drivers side floor after I dropped it down. If you are saying "whats the point" I understand..... But I am just trying to make the truck more comfortable to ride in because of the body drop I have to crane my neck just to see the traffic lights.
you can see how much I narrowed the tunnel
I know you guys know what it looked like before but Heres a before & after anyway
__________________
"If it was easy everyone would do it"
"You can't argue with RESULTS"
"Doing STUFF on the CHEAP =CHEAP STUFF"
  #92 (permalink)
Old 11-02-2009, 03:03 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is online now
1974 Ford F-250
ChaseTruck754 is gaining momentum as a positive member of FTE. ChaseTruck754 is gaining momentum as a positive member of FTE.
Tranny hump is offset because the motor and tranny are offset.
Hump is that way to give more room for the pedals on the driver side.
Work looks good - keep up with the pics.
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #93 (permalink)
Old 11-06-2009, 11:26 PM
This is what I brought home....My wife said what the hell did you buy that for
She was more than happy to spend a day at the Gulf coast 3 years later though...funny how that works ain't it
__________________
  #94 (permalink)
Old 11-07-2009, 04:31 AM
bmarkline's Avatar
bmarkline bmarkline is offline
bmarkline is starting off with a positive reputation.
I just found this build thread, read EVERY SINGLE POST haha. When u did your cowl vent, did you just plate over top the vents? I accually cut mine out and it warped all to **** because of the stresses on the stamped steel from being stamped. After that was a real pain in the butt.
To 77460, you can cut some holes in the front side of the cowl along the sides, inside the wheel wells. My '78 has a plastic wheel well liner then to keep water and mud out. Then I put little funnels under the wiper holes and drain tubes out the bottoms on the sides. Only reason I did it in the first place was water leaking from the bad old cracked seem sealer inside the wiper cowl. Heres some pics of it, I think the build shots are on page 2.
Ford pictures by bmarkline - Photobucket
Sorry, didn't meen to . Subscribed the thread!
__________________
www.myspace.com/visualrealitycc
  #95 (permalink)
Old 11-07-2009, 05:57 PM
77460ford's Avatar
77460ford 77460ford is offline
77460ford is starting off with a positive reputation.
I had rolling the windows down figured out, thanks.
bmarkline, great pics. Now I've got a better feel for removing drip rails and for filling the cowl. Great thread.
__________________
'77 F150 4X4 472/C6/4:11's/35's
2 - 50lb. Nitrous bottles
  #96 (permalink)
Old 11-07-2009, 08:26 PM
jm350 jm350 is offline
jm350 is starting off with a positive reputation.
FLATFORD1976 do you have any pics of your front airbag setup and if so could you post them, Thanks!
  #97 (permalink)
Old 11-08-2009, 01:13 AM
projectbad78's Avatar
projectbad78 projectbad78 is offline
projectbad78 is starting off with a positive reputation.
you guys that shaved your cowl, how did you hold the metal while fitting and welding and flatford, is your fill piece on top of the cowl?
__________________
http://i33.tinypic.com/wi7qx1.jpg
1978 F100 custom
351W
-offy intake
-'brock carb
C4
  #98 (permalink)
Old 11-08-2009, 02:00 AM
bmarkline's Avatar
Personally I buttwelded everything, so I used some of those adjustable welding magnets to hold the peices flush. But remember what I said about cutting out the vents, that cowl is under alot of stress from stamping at the factory, and when you cut out the vents it WILL warp-nothing to do with heat. So upon my rough adventure, I'd sugest that as long as you dont have a rain water leaking issue like me, then you should save yourself some headaches and just plate over them and be done with it.
__________________
  #99 (permalink)
Old 11-08-2009, 08:01 PM
93F22A6 93F22A6 is offline
93F22A6 is starting off with a positive reputation.
Quote:
Originally Posted by FLATFORD1976 View Post
the only thing about shaving the drip rails is on mine the door gap is large at the top of the door . if you look closely you can see it. I have not decided what i am going to do about it but I am leaning towards living with it
If you talking about the door sitting in (not flush) I have an idea for that. I took and put a pry bar between the upper door and the cab and slammed the door shut. The door set even, only thing is you have to make it keep that shape. My guess would be to heat it to releave the stress to keep the shape. I'm trying the bfh rubber mallet right now and it has not been succesful. I also thought about pie cutting the door (way to much work but it'll work) because on mine both the fron and rear tops sit below flush. As Far as the gap, when they come flush it's even just large, so the door hinges need to be slid back.
__________________
76' F-100 302 C4
DD-93' Accord 5spd
  #100 (permalink)
Old 11-08-2009, 11:18 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
1974 Ford F-100
My Garage
Bullitt390 is gaining momentum as a positive member of FTE.
You need fresh air for the heater to work, unless there is no need for a heater where you guys live.
I only had enough courage to delete the radio antenna hole.
Josh
__________________
1974 F100 Custom Styleside 428 Cobra Jet Dual Quad
  #101 (permalink)
Old 11-10-2009, 07:42 PM
whats up guys.
I have always wanted to try fiberglass work and I want to eventually build a dash but I figured my first attempt should be something a little less ambitious. So I started on a set of kick panel speaker boxes. I got the frames built, wrapped in fleece and a good coat of resin on tonight. I will see about building my dash after I get these glassed and mudded and ready for paint.
Here's a few pics of what I got done tonight. Remember.....my first time building anything out of fiberglass.
I have a little advantage as I am a carpenter so the wood frame was a snap
and My mom has done upholstery All my life so the fleece was easy too We'll see about the rest
__________________
  #102 (permalink)
Old 11-10-2009, 11:52 PM
lowriderf100 lowriderf100 is offline
lowriderf100 is starting off with a positive reputation.
sweet!!!!!!!!!!!!! keep the pictures coming
  #103 (permalink)
Old 11-11-2009, 01:01 AM
yeah, ive been wantin to play around with fiberglass too, you just usin fleece and resin or you using matting also?
__________________
1978 F100 custom
351W
-offy intake
-'brock carb
C4
  #104 (permalink)
Old 11-11-2009, 02:54 AM
bmarkline's Avatar
Quote:
^^^What he said^^^x2
__________________
  #105 (permalink)
Old 11-11-2009, 12:33 PM
jsutton's Avatar
jsutton jsutton is offline
1977 Ford F-100
My Garage
jsutton is starting off with a positive reputation.
I thought about doing some kick panels in mine, but it may block use of the emergency brake. And possibly the dimmer switch for the headlights. So I haven't done it yet. I've made some before for other cars I've had and I never had to add matting for just some mids. Now if this was for a sub then matting is a must.
It's looking good!!
__________________
'77 F100 302 C4 John Deere Blitz Black and Cragar Soft 8s
http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=202355&.jpg
Tags
79 , 82 , affiliated , body , custom , dropped , dropping , f100 , frame , hood , laying , part2 , pics , ranger , step , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
