Stuck in 4 LOW !
Stuck in 4 LOW !
I have an 05 F150 FX4. I pulled someone out of the ditch last night in 4 low. Once done, I couldn't switch back to 2H or 4H or anything. Had to drive back home (1/4 mile at a snales pace). I tried putting in Neutral, switching back & fourth from 2H to 4L. It doesn't change. Tried backing up, going forward. It is just stuck. How do I dissengage it so that I can go to dealership?
I have had that problem before too. It took me a hour one time and another time half an hour. Both times for me to get it out I had to either drive backwards and hit the brakes really hard and drive forward and hit the brakes too and put it in Neutral or Park and try to switch it over. The other time I actually put the truck in Neutral on a flat surface opened the door and pushed the truck back and fourth and it came out. I had no one to help me so I had to push it myself. It was a pain but finally got it out. Found out I had 2 bad hubs and a silinoid go bad. It all happened after I put my truck in the truck pulls at the local fair. Last time I will do that. See if someone can give you a hand and try rocking it back and forth in Neutral and when they go to push the opposite way hit the brakes hard.
Someone told me if you pull something out thats really stuck or giving you a hard time it puts alot of stress on it and you have to hit the brakes hard to get it out. Seemed weird to me but it worked for me.
I tried this and it did not work. I also tried disconnecting the vaccume hoses & the electrical plug from the solinoid. Then I tried disconnecting the battery for 20 min. Neither worked.
Thank you.
Had a similar problem last night. Believe it may have been the first time I ever put my '06 in 4L. Tried to exit 4L while in Park and Drive, nothing, moved forward and backwards, nothing. Read the manual and it indicated Neutral was required. Did that and instantly I was able to exit 4L. Whew! I was afraid I was going to be in your boat. Fortunately for me it was just typical OE. Glad you succeeded.
No, you go from 4H to 4L in N and back from 4L to 4H in N. Then from 4H to 2H. Your not supposed to go from 4L straight to 2H, but it may work anyway.
Seaville
01-24-2017 08:09 AM
grizzle383
Bronco II
06-29-2006 04:09 AM
