I have a basic question for ya’ll. Are all fe blocks the same. I have been told that there is a difference in the motor mounts. Some Fe are for cars and others for trucks.
I was competing an engine for my truck some years ago and this older bench racer told me to be careful about choosing blocks. I had bought a block from a junk yard and was rebuilding it while I still drove the truck.
Well the block and motor mounts fit so I was relived. But the question has all way been at the back of my head.
Yes I have seen the different bolt patterns with the motor mounts between 2 and 3 bolts. The newer FE trucks had 2 bolt and the older FE cars have 3 motor mount bolts. But will the older pattern mount up to newer perches, IDK.
__________________
1975 Ford F-250 4x4 360FE
2001 Ford Expedition 4.6
1986 Toyota 22re 4x4 (DD)
Some call me Alex....
Wrong, the old original pattern is two bolt for cars from day 1 of the FE engines back in 1958. The reason for the change to 3 bolt was that it was felt that 2 bolt was not strong enough for the trucks.
__________________
Bear 45/70 Gimp Racing
“There are only two things stopping you, common sense and fear! And not much of the latter.”
I'll drink to that.
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
Which is strange, as every truck motor mount I've seen for the FE in the 73-77 range has been a two-bolt mount.
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased! I've been wrong before, I'll be wrong again. Just wait and see.
That is the exact mount that was on the 375 hp 390 out of a 1961 Custom, which was hell to put into my 1966 Comet because of the 2 bolt mounts on the engine and with the car having the 3 bolt mounts. My 1968 F250 Camper Special with 390 had 3 bolt mounts.
Bear, those are the exact mounts used on the 70's pickups. 2-bolt.
Can't say about the pre-73, as I've never seen one first-hand.
__________________
Got me looking and the block I have in my car is a 68 and it's a 3 bolt, the 67 galaxie called for that one. The D4TE block I have is a 2 bolt and that is obviously out of a pickup. I thought the only ones that had the 3 bolt were the FT blocks but guess thats not right
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
