f-350 rear brake locking up - Ford Truck Enthusiasts Forums
Old 10-08-2009, 01:18 PM
f350lord f350lord is offline
f350lord is starting off with a positive reputation.
I have a 85 f-350 4 door dually diesel. My problem is My one rear brake is locking up every time I use the brakes, after I let off the brakes it spins free. I put on a new master cylinder all new brakes and wheel cylinders and still have problem. Any ideas?
Old 10-08-2009, 11:56 PM
Built_Ford_Tough_757's Avatar
Built_Ford_Tough_757 Built_Ford_Tough_757 is offline
Built_Ford_Tough_757 is starting off with a positive reputation.
Nothing is messed up on the drums is it? My shoes on my truck got messed up last night from testing my E-brake (fail) and one shoe was demolished... Making noise using them and locking up when I was almost stopped, so take a look if you haven't yet. If it looks good, I would say the cylinder on the drums are bad. The part that pushes the shoes outward. I think its called the cylinder. Good luck.
Old 10-09-2009, 12:04 AM
Redneck1465 Redneck1465 is offline
Redneck1465 is starting off with a positive reputation.
He said he put new wheel cylinders in...
Old 10-09-2009, 12:11 AM
I've tried everything I can think of. My brake locks up right when you put the brakes on. The drums are good, no marks, no digs. The wheel cylinder is new but didn't help. tried loosening everything and it still does it. right now everything under the drum is new, It is only the right side, so I don't think it can be the rubber line. I am starting to think that I might make the other side do the same thing and enter some drifting comp's or rally races.
Old 10-09-2009, 01:41 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
I have seen this happen when someone puts the two long shoes on one side, and the two short ones on the other side.
Old 10-09-2009, 02:08 AM
forum155pl's Avatar
forum155pl forum155pl is offline
forum155pl is starting off with a positive reputation.
Quote:
holy crap there is differant sizes?
Old 10-09-2009, 09:35 AM
The long shoes go on the back side, right?
Old 10-10-2009, 12:19 AM
Quote:
Oh, sorry. I missed that.
Old 10-10-2009, 01:17 AM
Franklin2's Avatar
Quote:
Yes, I believe that is correct.
Old 10-10-2009, 08:41 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
yes, primary (short) shoe goes in front, secondary (long) in the back the shoes were never soaked with brake fluid or gear oil were they, that will cause lock up
Old 10-11-2009, 10:02 AM
axman_F250's Avatar
axman_F250 axman_F250 is offline
axman_F250 is gaining momentum as a positive member of FTE.
Sorry if these are dumb questions..
Are the pins that transfer wheel cylinder effort to push the shoes out completely engaged in the shoes?
Were the bosses on the backing plate grooved or worn excessively?
Was the brake adjusted after your rebuild? Drum spins, light friction without brakes applied?
Adjuster facing the right way?
Do both shoes show evidence of touching the drum?
Does one shoe (primary or secondary) show more evidence of touching the drum? Might look closely at the top edge of friction material - closest to the anchor boss, or at the bottom, closest to the adjuster.
If one shoe is showing more evidence of wear than the other, it might lead you to what is happening.
Old 10-11-2009, 03:41 PM
The shoes did have some brake fluid on them from the leaking cylinder, but I didn't think it was enough to hurt them. I'll try new shoes.
Old 10-11-2009, 05:13 PM
Franklin2's Avatar
Aha! That will fix your problem. Make sure to clean the brake drum really good too. When the shoes try to start drying out, they start to get gummy and will grab.
Old 10-11-2009, 08:23 PM
Can I just clean with brakes with cleaner or are they shoot. Thanks for all the help.
Old 10-11-2009, 08:45 PM
Franklin2's Avatar
Cleaner won't work. They are like a sponge and are soaked. Each time they get hot the old fluid is going to seep out. Believe me I am a penny pincher myself, but have never been able to get brake fluid out of the shoes and pads.
Sometimes on equipment that has to be running and we don't have the parts in stock, I have taken a torch and played the flame over the shoes to burn the oil out of oil soaked shoes. But this is just a temp solution in a crises.
73F600 Rear Brakes Lock Up ncaaref Large Truck 12 10-17-2016 08:15 AM
Brakes lock up after MC replacement fl-mitchells 1973 - 1979 F-100 & Larger F-Series Trucks 16 03-15-2013 02:43 PM
Rear brakes sticking Brads-idi Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 02-22-2011 11:59 PM
rear brake sterling axle 47,52,69,92 1987 - 1996 F150 & Larger F-Series Trucks 2 04-09-2010 06:00 PM
95 f250 brake nightmare grady420 1987 - 1996 F150 & Larger F-Series Trucks 15 04-01-2009 01:19 PM
Tags
1999, 99, brake, brakes, diesel, f150, f350, ford, grabbing, locking, photo, problems, rear, replacement, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
