Heater Core: Replace or Not?
The windshield of my '93 (5.8, 150k) keeps getting that lovely anti-freeze film over a period of time. I don't drive the truck much, so I really have no idea how long it takes. The cooling system was recently flushed, and is setup with 50/50.
For simplicity sake, should I add in a little stop-leak, or just go ahead and swap out the core?
Thanks!
Thanks!
Thanks!
Thanks!
I've noticed that trucks don't turn into "junkers" overnight, they get there gradually ... usually one postponed project at a time.
I just replaced the heater core in my wife's Chrysler LeBaron over the weekend. It took 6 hours in a professional shop, and every single piece of the dash you can imagine had to come out, then there were parts in there that you probably hadn't imagined that had to come out. The VISORS had to be removed as part of the process to get the heater core out.
That's the kind of vehicle that a heater core change is the last effort you make in fixing the heater.
A Bronco on the other hand... You're probably looking at an easy thirty minutes, maybe a little more if you have A/C. The heater box is in the engine bay, where it should be. Remove the bolts holding it on (a few are behind the glove box I believe), pull it out, put in a new $30 core, and put back together. Problem solved.
Depending on where you live in town, acquiring the heater core may take you longer than putting it in.
ladelld33
02-25-2013 08:46 PM
Trodgers50
01-14-2013 10:56 AM
jpgrdmb14
10-15-2006 03:01 PM
