constant drain on battery
Ihave a 1991, 4 door explorer i have repalced a countless3 on batteries in it and to no evail the batterys keep discharging , i have replaced the alt , starter ingnition switch , starter, both the neg, and pos, cables and am still havint the same problem , i was told that the origanal ford radio was causing my problem so i disconnected it , and for a while had no problems , so i replaced it with an aftermarket stero and now i`m at the same problem again , any suggestions , i`m dyin here.
