98 Windstar, 3G ?
The 3G alternators can be adapted to the old wiring harness. Look a couple pages back for my thread on NEED ELECTRICAL EXPERTISE. M.L.S.C sent me a wiring diagram that is used for the mustang conversion but all the wire colors are the same. As for the alt. itself it depends on the mounting holes. Don't see why it wouldn't fit, just some shims and maybe grinding to get perfect fit. I have a chevy single wire alt. that is self-excited running on mine. I switched to that one because I kept having issues with volt. reg. blowing and going through alts. So I just ground the bracket for the bottom bolt a little and drilled the bottom hole on the alt out a bit and it bolted right up. Have had it on the truck for 4 yrs. without a problem til it went out like two weeks ago. I'm putting the 3G alt. on mine soon but its from a 94 IDI. I'm installing that with all the rest of the setup to convert it to serpentine belt.
And now I gladly step off this long soapbox session.
poorfatkid
1983 - 2012 Ranger & B-Series
09-21-2012 10:52 AM
PlayMechanic
3.8 & 4.2L V6
11-19-2010 11:00 AM
okanagan98
08-28-2001 12:50 PM
