Go Back   Ford Truck Enthusiasts Forums > Ford Truck Enthusiasts Site Navigation > User Gallery & Picture Display Help
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-17-2002, 07:28 AM
wmclott wmclott is offline
Garage is empty, add now
wmclott is starting off with a positive reputation.
Post Proper method for checking compression
I have a 92 Flareside 5.0L w/AOD tranny. The engine seems to have a miss throughout the rpm range and struggles going up hills and bridges. I have to shift out of OD to compensate. I had my local Ford dealer run a diagnostics and was told that I have low compression in one cylinder. The truck has 119K miles on it. There is also a sucking noise that I hear when I turn the engine off. It lasts for a few seconds and dissipates as pressures are equalized. It sounds like a vacuum leak but I'll be darned if I can find it.
I want to check compression to verify the Ford dealers findings but the manual (Haynes) I have does not address it.
I would also like to know how the engine would be affected if the catalytic converter is restricting exhaust flow. How would the conditions be manifested? I know that restriced flow will have detrimental effects but have never experienced them.
I appreciate any words of wisdom.
  #2 (permalink)
Old 02-17-2002, 10:43 AM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
Founder ... Stay Tuned
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
Post this in the 87-96 section. This section is for the User Gallery.
__________________
The best is yet to come....
  #3 (permalink)
Old 02-19-2002, 07:05 PM
mustange70's Avatar
mustange70 mustange70 is offline
mustange70 has a good reputation on FTE.mustange70 has a good reputation on FTE.
__________________
Cody, Calgary
AB
82' Flareside: 2/4 Drop, 350hp 351W, Custom interior
81' 250 mudder: home fabbed lift & dana 60 SAS , 450hp 400, 4sp/205, 38" tsl's
Tags
checking, compression, engine, f150, method
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
