Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 10-29-2009, 08:33 PM
Happyreefer's Avatar
Happyreefer Happyreefer is offline
1994 Ford F-350
Happyreefer is starting off with a positive reputation.
recieved the new starter..
removed the first DB Electrical starter and thought I would see the starting gear torn up pretty good from the metal shavings from the grinding I was hearing. The starter gear looked pretty good, but could see where it was making contact to the flywheel.
installed the second DB Electrical starter they sent me due to the first one grinding. Well, this one sounds better, but still sounds like it is grinding a little.
Can someone that ordered this "higher torque" starter from DB electrical describe the best they can how the starter sound. I know it sounds like a weird request. I know this is a reduction gear starter vs. the Mitsubishi type and probably sounds different when all is working correctly, but it just sound odd.
Also, I thought I read somewhere that someone had flywheel issues when using a reduction gear starter, don't know where I read that thought. She does start faster than she has ever started even with the grinding sound.
__________________
1994 Crew Cab F-350 7.3 IDI Factory Turbo 3" Downpipe to straight pipe
E4OD - 4.10's - 35" Mud Terrains Gear Venders Under/Overdrive
ISSPRO Gauges: Pyrometer, Water temp, trans temp, turbo boost
"But can it crush cars?"
  #17 (permalink)
Old 10-29-2009, 09:27 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
The Mitsubishi and Nippondenso are both gear reduction starters.
AC Delco is the only direct drive starter for the IDI.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #18 (permalink)
Old 10-30-2009, 12:36 AM
Knox's Avatar
Knox Knox is offline
Knox is starting off with a positive reputation.
I just ordered a Nippondenso like that from Nampa for 200 delivered tomorrow
wish I had known about this earlier
i used a thumb wheel ratchet with an extension to get the top bolt off
Tags
69 , 73 , bolt , diesel , direct , drive , ford , gear , high , idi , powerstroke , reduction , starter , starters , torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
