porportining valve - Ford Truck Enthusiasts Forums
porportining valve
Old 10-07-2009, 07:58 PM
stanyol69 stanyol69 is offline
stanyol69 is starting off with a positive reputation.
porportining valve
Number dummy, I went to an auction sale and bought a box lot of ford parts. In the box was a porportining valve. The number is d5ta-2b328-c1a It has never been installed. wondering if you could tell me what it went to? thanks in advance stan
Old 03-03-2014, 06:37 PM
jbancroft jbancroft is offline
jbancroft is starting off with a positive reputation.
You still have that? Part? I have 2 F250's with the same number. Most people will say its D4tZ-2B257A for the 76 F250, but ya never know! that number is for a 1976 F250 trailer special. Front Disc, rear brake, 8500 GVR
Old 03-03-2014, 09:48 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Unless you're doing a restoration, ditch the whacky and troublesome factory prop valve and go aftermarket.
Here it is mounted... and I have a bad attitude about any kind of plumbing be it automotive or residential. .. totally detest it.
Old 03-04-2014, 09:59 AM
Thx HiO, clean looking installation. I hear ya, that valve is really hard to find & expensivo- might try one of those adjustables.
did you fabricate that bracket yourself?
Old 03-04-2014, 10:24 AM
trozei's Avatar
trozei trozei is offline
trozei has a great reputation on FTE.trozei has a great reputation on FTE.trozei has a great reputation on FTE.trozei has a great reputation on FTE.trozei has a great reputation on FTE.
He did fabricate the bracket himself but it is now offered by Wilwood for an extra $32 on top of the $84 price of the proportioning valve.
Old 03-04-2014, 02:50 PM
thanks. while I'm in there, looks like I'll have to fabricate some new brakelines - ugh. Do you recommend just getting a roll of tubing and flaring them myself, or finding pre-cut? seems bending & flaring myself could result in a cleaner install.
so then, steel or cupro-nickel?
suggestions?
Justin
Old 03-04-2014, 03:47 PM
yetiman38237's Avatar
yetiman38237 yetiman38237 is offline
yetiman38237 is gaining momentum as a positive member of FTE.
You can get a mini bender at HF for a few bucks. Parts stores like Advance have pre cut sections of hard line for a few bucks a foot. Pretty simple if you know end sizes you need. I reused some of my ends.
Old 03-04-2014, 03:48 PM
Quote:
. You will have to flare end if you custom cut. HF has those too.
Old 03-04-2014, 03:58 PM
HIO Silver's Avatar
so then, steel or cupro-nickel? suggestions?
Justin
You know what my answer is.. fab 'em up! It's a skill worth learning IMO.
Speedway Motors is a good place to hit up for tubing and fittings. Their $10 cutter is what I use.. Start reading this for more info...: http://www.ford-trucks.com/forums/11...l#post13542395
Old 03-04-2014, 04:24 PM
trozei's Avatar
Using a zippy disc on a grinder is actually considered to be better. The tube cutter hardens the end of it, often causing unwanted results when you go to flare it. Zippy cut, run a drill bit through the inside, file down the outside, then flare. You should get smooth, consistent results.
Old 03-04-2014, 04:50 PM
I always used a hacksaw and chain file.
Old 03-04-2014, 07:23 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
You still have that Part? I have 2 F250's with the same number. Most people will say its D4TZ-2B257A for the 76 F250, but ya never know!
That number is for a 1976 F250 trailer special. Front Disc, rear brake, 8500 GVR
1956 thru today: Numbers marked on parts are casting or ID engineering numbers, not part numbers.
D4TZ-2B257-A .. Brake Pressure Differential Valve / Marked w/ID engineering number: D4TA-2B328-A1A or A2A or D5TA-2B328-CA or C1A or C2A
Applications: 1974/79 F250 2WD with 6900, 7500, 8100 lb. GVW's with dual piston caliper front disc brakes / 1974/78 F350 / 1975/79 E250/350 / 1979 F350 2WD
Most people wouldn't say anything because they have no parts catalogs. So they have no way to look up the part numbers and their correct applications.
Valve cover hose barb? ROBBINthaHOOD Modular V10 (6.8l) 1 11-16-2016 09:10 PM
PCV Elbow for 2001 F-150 XLT 5.4 V8 goose4wind 1997 - 2003 F150 5 02-17-2016 07:40 PM
ats turbo air filter part number m8094538 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 10-06-2010 10:41 PM
CDR part numbers jalopy45 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 03-17-2009 01:48 PM
PS Conversion questions White97 1961 - 1966 F-100 & Larger F-Series Trucks 5 07-01-2008 04:09 PM
Tags
d5ta2b328c1a
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
