Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-07-2009, 03:05 PM
ghunt's Avatar
ghunt ghunt is offline
ghunt is gaining momentum as a positive member of FTE.
Looking for input on bumper design
Hey guys,
I'm drawing up some bumpers for my truck because I've wanted to put on some nice front & rear bumpers basically since I got the truck. A guy that we do a fair bit of business with at work runs a machine shop and has a CNC cutter, so basically anything I can draw in AutoCAD, he can cut out of sheet steel I figure if I can have him cut it out for me, I can do the fitting and light welding (and maybe tack on other stuff) and then have him weld the important stuff.
So, this is my preliminary bumper design so far:
Main thing I'm wondering about is plate thickness...I was thinking 1/8" diamondplate steel for the top, ends, and angled bottom pieces. The main body is 4" Sch. 40 pipe, and the center step/license plate mount is 3/8" plate. Should I go with heavier plate? I don't have the frame mounts figured out yet, and I'm not sure what the best way to go about that is, BUT should I use 3/8" or 1/2" steel for those?
I'm working on a front bumper too but it's still in the works.
__________________
1994 F250 XLT-Reg cab, 4x4, 5 speed, 7.3 IDI Turbo, manual hubs. 4" intake tube, ATS upgrade, 4" exhaust w/ Walker 21172, boost & pyro on pillar, Autodim mirror, 16x8 MB Razor wheels w/285/75R16 "MT-R's"
1987 Thunderbird Turbo Coupe-Lots of fun stuff to make it go fast & take corners
2008 V-Star 1100 Midnight Custom-Just Cobra slip-on drag pipes for now
  #2 (permalink)
Old 10-07-2009, 06:19 PM
75F350's Avatar
75F350 75F350 is offline
1973 Ford F-100
My Garage
75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all
The problem with A Cad is the lack of dimension. It is diffuclt to tell what you are trying to accomplish and to see where the structure comes from.
I mean is the pipe going to the a solid piece and your license plate stuff is just going to weld to it, or will you have a section of pipe missing from the center and the licens plate area will be wide open? If you leave it open, keeping it square while welding will become a task all by itself, and you will compromise structural strength.
Have you played with "Solidworks"? You may find this program to be superior.
On a side note, these pieces appear to be rather straight cuts, and you are not working with anything here that cant be cut with accuracy at home. You wuld be amazed at how straight you can make a cut with a 4" wheel and a grinder.
Draw the lines, use tape to create them, and cut along the tape. You can create super straight cuts, that your basic design requires, and use far less material.
This can also be done with a sheer, but I am not sure that I would waste the amount of material required to throw this onto a CNC table.
  #3 (permalink)
Old 10-08-2009, 04:20 AM
Bender99's Avatar
Bender99 Bender99 is offline
1991 Ford F-150
Bender99 is starting off with a positive reputation.
3/8 should be fine for the center section, although we cant really see the design for it and I dont know what kinda weight you plan to put on it. Seems that your drawing needs a little work. Do you mean to have the center section sticking out like the top view or would it be flush like the side view? Is the pipe supose to be positioned like you have it in the side view?
__________________
91 Shortbox F-150, 302, ZF 5 speed, Dana 44HD SAS, Dana 60 rear, 8'' Suspension Lift and 38'' TSL's.
Mustang lx, 2.3, 5 speed. Nothing cool except gas mileage!
  #4 (permalink)
Old 10-08-2009, 10:12 AM
ghunt's Avatar
Well, what I wanted to do was cut a piece out of the pipe the size of the license plate bracket thing, about halfway back into the diameter of the pipe, and weld a plate in there to be the backing for the license plate panel...then weld on the sides, and bottom, and I figure that would put some strength back into the pipe from being cut.
And yes I mean for that part to be sticking out...as far as I can tell that's how Ranch Hand does their bumpers. But I can't tell from pics and I don't really know anyone that has one I could look at to see how they are actually put together.
Oh, and why would there be any more waste material from cutting the stuff out with a CNC cutter as opposed to doing it with a cutoff wheel? I end up with odds and ends either way. It'd be a lot faster and less of a chore to use a CNC cutter, and I'm gonna have to buy a full sheet anyway, and it's probably easier than cutting the stuff out in my garage.
__________________
Tags
bumper , bumpers , cad , cadd , design , designs , dimensions , f150 , f250 , ford , hand , pipe , ranch , truck , welding , work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
