Don't know your model year, but the mid 90s F250s had different fluid front versus back.
The rear if it is limited slip will have a tag on it that I believe says blah blah L or LS somewhere in there.
Even if you don't put in the additive you can check easily. Just do some tight slow speed turns. I seem to get most obvious results while backing out and turning tight.
If the truck chatters then you need additive. Usually 1 toothpaste tube will do.
Chattering feels like the tires are grabbing or rubbing against the wheel well.
I forget what fluid is in the front diff. I think it is ATF but I forget.
Jim Henderson
Thanks for the advice. I have a 1999 F250 SD, lariat, 4X4.
I believe the front is a dana50, and will require 70W-90 gear oil. The rear requiring 75w-140.
Here's my VIN: 1FTNW21L0XEEJ6930 can anyone out there answer this one way or another??
Thanks,
John
__________________
1999 F250 SD Lariat - Crew Cab, 4X4, Shift on the floor, 5.4L V8. 100% stock...for now 211,789miles
Sorry if this has been asked/answered a million times already. I just want to make sure I do things right. I am still very much a shade tree mechanic, so I learn as I go.
Your help is greatly appreciated.
__________________
need to look at the cert,label in the door will be a 2 place axel code then check the sticky on top of this fourm
__________________
03,f250,sc,sb,xlt,RED,5.4,4x4,4:10LS,western 7.5 ultramount and just a touch of hypertech wifes gotta 03 sport trac xlt with all the bells
