Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
General Diesel Discussion SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-07-2009, 03:36 PM
ghunt's Avatar
ghunt ghunt is offline
ghunt is gaining momentum as a positive member of FTE.
Automatic starting fluid injection system...???
At my work we have a '97 F800 flatbed with a 12V cummins in it.
The hood was up the other day and I happened to notice a sticker on the air filter housing that says:
"NOTICE!
This unit is equipped with a KB Dieselmatic Automatic Starting Fluid Injection System
DO NOT ADD ETHER OR USE AEROSOL CANS"
WTF is an Automatic Starting Fluid Injection System and howcome we've never had to refill it?
I figured the engine just had a grid heater like most 12V cummins. I do know that it doesn't have a wait to start light, and on most days that are above freezing you can turn the key to the notch before start for about 5 seconds and it will fire right up. It doesn't even have a block heater, but it still starts fairly well on cold days (just runs rough for a little while).
__________________
1994 F250 XLT-Reg cab, 4x4, 5 speed, 7.3 IDI Turbo, manual hubs. 4" intake tube, ATS upgrade, 4" exhaust w/ Walker 21172, boost & pyro on pillar, Autodim mirror, 16x8 MB Razor wheels w/285/75R16 "MT-R's"
1987 Thunderbird Turbo Coupe-Lots of fun stuff to make it go fast & take corners
2008 V-Star 1100 Midnight Custom-Just Cobra slip-on drag pipes for now
  #2 (permalink)
Old 10-08-2009, 05:44 AM
mistakenID mistakenID is offline
mistakenID is gaining momentum as a positive member of FTE.
There should be a canister of starting fluid on a bracket someplace in the engine compartment. It looks kind of like the small tank for map gas. There is a line that runs to the intake, a temp sensor on the block.
When the temp is low enough when you start the truck it will automatically give a shot of either. The ones I had on my semi's were a manual push button. When the tank is empty you loosen the clamp, unscrew the tank and replace with a new one.
__________________
86 F-250 4x4
Cummins BT 5.9
GearVendor O/D
  #3 (permalink)
Old 10-08-2009, 06:55 AM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is online now
Maxium4x4 is a splendid one to behold Maxium4x4 is a splendid one to behold Maxium4x4 is a splendid one to behold Maxium4x4 is a splendid one to behold Maxium4x4 is a splendid one to behold Maxium4x4 is a splendid one to behold Maxium4x4 is a splendid one to behold
Like he said, look around the engine area and you will see a can, probably empty if no one has changed it. The Do Not Add or Spray is because you can lock the engine applying to much starting fluid.
__________________
http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=209298&.jpg
Read First FTE Guidelines ULSD Click Here
2003 F-350 Reg Cab 6.0L-Custom Programming 424.59HP-669.67 Torque
  #4 (permalink)
Old 10-08-2009, 08:53 AM
Frankenbiker's Avatar
Frankenbiker Frankenbiker is offline
Frankenbiker has a good reputation on FTE. Frankenbiker has a good reputation on FTE. Frankenbiker has a good reputation on FTE.
The one I had on my old company truck looked about the same size as the refrigerant dessicant canister. It was on the other side of the engine, though, and painted orange.
-blaine
  #5 (permalink)
Old 10-08-2009, 10:53 AM
ghunt's Avatar
Ohhhhhhh....I bet that's what the one empty round bracket in the engine compartment used to have in it then.
__________________
Tags
1997 , 73 , automatics , bracket , button , fluid , ford , injection , injector , push , semi , start , starter , starting , system , thunderbird , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
