manual trans swap c750
Does anyone know anything about the eaton fuller 4-A-86 trans from I am guessing a 1965 american 7450 crane? It was the only thing I could find any mention of such a trans being used in. It has the similar shifter apparatus on top of it like the c series has, only it points to the opposite direction, driver side. From what I can tell it may be a 10 speed, not sure if thats a good thing or not. I'm looking at replacing the clark 5 speed and wondered if this might work?
As far as I can tell, there is not much to be found via google for that trans, which is not unusual for big truck stuff that old.
Is that a 4 speed? The closest I found comes up a 4 speed:
https://www.eaton.com/rr/ProductsSer...ons/PCT_486870
By comparison, the Clark is common.
- AMERICAN 7450 CRANE, CUMMINS ENGINE, 120' 59'' TUBULAR BOOM, 3 PHASE TORQUE CONVERTER, 3 DRUM SYSTEM
AMERICAN 7450 CRANE, CUMMINS ENGINE, 120' 59'' TUBULAR BOOM, 3 PHASE TORQUE CONVERTER, 3 DRUM SYSTEM POWER DOWN ON ONE DRUM, 68 TON RATING W/ HOLLOW COUNTER WEIGHT, HENDRICKSON TRUCK SYSTEM, MODEL 75-CH SER # 65-6028, DETROIT ENGINE, 4-A-86 FULLER 10 SPD W/ 3SPD AUX TRANSMISSION 3-A-92, 14-20 TIRES
1968 c750 with a clark 5 spd, looks like it will bolt up as it already has a SAE bell housing on the fuller, will need some fab work to adapt the ford shifter assembly onto the fuller.
Curious tho, does a 10 spd trans have only 3 shift rails? I don't see any external connections for anything other than the clutch and remote shifter head.
A fuller 10 spd is a 5 spd trans with a hi/low range splinter on the rear of the trans normally operated by a air switch on the shifter handle
The fuller tran has a SAE bell housing but unless you C-750 has a diesel engine it normally won't have.
A C-750 will probably have a 361 gas engine that has a round bolt pattern but that just a FE/FT bolt pattern, not SAE
What's wrong with the Clark trans
Nothing wrong other than rpm's it wants to operate at and the fact that I would like to put a desiel in the truck, the school bus rear axle seems to be very common and Vanderhaugs ? has many ratios to make the diesel happy.
Ah, so that bellhousing is not going to work. I guess I need an SAE bell as well now, would it be a #2 bell?
hayman68
06-25-2014 03:42 PM
Brian
09-06-2007 01:55 PM
