Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Oregon Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Oregon Chapter Join Chapter, Leader: Fabmandelux
  #1 (permalink)
Old 10-07-2009, 11:16 AM
billschmitz billschmitz is offline
2002 Ford F-250
billschmitz is starting off with a positive reputation.
02 F250 diesel lacking power
I have an 02 F250 super duty. I bought it new.
I have a K&N air cleaner, 4" down tube and exhaust, Hi flow muffler and a superchips tuner.
The truck worked well for years with my modifications. The last couple of years, though, i have had problems.
With the truck programmed to any of the settings (other than stock), if i drive it hard, or pull a big load up a hill, the engine light comes on.
For an experiment, i programmed it back to stock and took my travel trailer on a trip. Clearly the truck was not able to pull any load up a hill. The engine looses power and shifts down to second. Once in second it continuously cycles - the RPM goes up a bit, then the waste gate opens and dumps pressure, then the RPM goes back down. Over and over it cycles. I have to back way off the throttle, eventually it shifts to third gear and stops cycling. But not much power
With the truck programmed it has plenty of power. It is possible to pull almost any hill without the check engine light coming on as long as i am careful to not push it too hard.
My thoughts have been to replace the turbo and wastegate.
  #2 (permalink)
Old 10-07-2009, 05:11 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
First, let me welcome you to the Oregon Chapter. I only have IDI Ford diesels, so I'm not much help..............I would contact FN74 ( he is one of our sponsers) He has a shop that specializes in PowerStrokes, and SuperDutys. He is located in St Helens Or. Linky: StrokeShop - Home
I myself would not suspect the turbo or waste gate. If either one of them was bad it wouldn't work OK with the tuner.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 10-10-2009, 12:13 AM
JockD's Avatar
JockD JockD is offline
Garage is empty, add now
JockD has a good reputation on FTE.JockD has a good reputation on FTE.
Post this in the 99-03 7.3L forum of FTE. There are lots of folks there that know these engines (and tuners) well! They will pitch in and help.
__________________
Jock - 2001 F250 Reg. cab 4X4, 7.3L with CCK, auto, 280,000 mi., homebrew pw and pdl, heated towing mirrors with a timer. Stahl Grand Challenger Utility Box, Ride-Rite Air Bags, Big Rear Sway Bar, Walker BTM + Resonator.
Tags
02, 2001, 73, diesel, downtube, exhaust, f250, ford, forum, lacking, power, powered
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
