Cab Mount bushing hardware???? 1978 F150
I'm building a 1978 F150. I took the cab off one chassis and am attempting to assemble it on a different one. Of course the old bushings are rusted beyond recovery.
I ordered the cab mount bushings from JCwhitney and they didnt come with the washer\sleeve hardware to fasten them to the frame.
Anyone know where to find this product outside a ford dealer? I've searched all over the internet, local autoparts store and havent had much luck.
Try this place. Not cheap, but a good place to work with.
1967-79 Full Size Truck/bronco - Bushings/polyurethane - Body Mounts & Hardware
I got the complete set up from LMC, called broncograveyard for the complete setup, they told me the poly bushings were on a backorder LIST that MAY be a month wait until the order and then it goes by who was on the LIST 1st, LMC said 1 week backorder for oem bushings ...but was advised by both companies that the bushings and sleeve kit may vary, when ordered seperately... so check for fit and length before the install as to not turn into unexpected problems when the time comes for putting it all back together, the oem rubber bushings and all the hdw. from lmc appear to be of good quaility. My rubber bushings lasted over 32 yrs, but the steel rusted away ....I went w/ the rubber bushings because I want more of an vibration isolation factor over the length of time it will take to wear.
crazed87bronco
10-28-2014 12:51 PM
Aaron-71
19
06-18-2012 12:03 PM
TOPHER1978F150
03-07-2010 12:27 PM
