Power Doorlock Problem
99 F250 LD 5.4 4x4
I have a problem with both door locks. Depress the buttons , lock or unlock and theres a click but nothing happens. Put the truck in gear and both locks lock. I still have to unlock them with the door handles or key. I thought that it might be bad solenoids but why do both doors lock when in gear? Any suggestions?
Same issue. Key will mechanically unlock the doors (Truck has no keyless entry). However from inside the truck, the electrical door switch will only lock the doors, not unlock them. Not sure what keeps the "unlock" part of the switch from working. If I punch the switch real quick the unlock part will work sometimes. I'm looking for a control module also, or I'll check out the actuator next.
you must have something aftermarket in there..do u use a key fob made my ford?
What i think it is..is your switch is messed up for the doors..but ur after market puts it into lock which means the actuators must be good..
try this:
throw the truck in gear...should lock it...
put it back in park..should unlock it..
if not try turning the car off but dont open the door and see if it unlocks itself?
try this:
justwufn
07-29-2002 06:05 PM
