1/2 ton SAS (Solid Axle Swap) guide
#46
#49
#51
Has anyone cut the engine crossmember and plated it to reinforce it so you don't have to run a 4" lift?
just looking at it and it looks like I could gain a good 2-3 inches of clearance by trimming the ttb mounting section of the crossmember.
Not looking to do much offroading except for the dunes so I don't really need the flex and articulation.
#52
i've seen it done to a lot of trucks, but never without any lift. it's generally done by guys running 4'' lifts that are running into issues with the axle contacting the x member, so i'd say you are probably s.o.l. if you think you can go dune hopping with no lift and not have contact issues with zero lift.
#53
#55
#56
^^^^sorry i don't have an answer for you on that and i'm not in the mood to search right now, but.......
i just reread this and i have a little tidbit to add for the guy who planned on using his ttb lift springs to do a sas or anyone else who plans to try it; don't do it.
the ttb springs are way the hell stiffer by design of the ttb axle and they won't flex worth a shyte with a mono beam axle. ttb springs are a heavier rate to accommodate the "wing action" of the ttb axle's movement and radius arm design. it might not make sense to some, but trust me, i read it on the interweb and i am an expert
#58
http://i87.photobucket.com/albums/k1...Picture082.jpg
What is that bracket for? im assuming u had to custom fab it?
#59
