1/2 ton SAS (Solid Axle Swap) guide - Page 9 - Ford Truck Enthusiasts Forums
  #121
Old 10-05-2012, 07:59 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen ManfredVonRichtofen is offline
ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.
Ok...I do it.
Wonder if I can buy a 120v arc welder and do it?
  #122
Old 10-05-2012, 08:04 PM
alpha/omega's Avatar
alpha/omega alpha/omega is offline
alpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to all
Id rather see you find a used Lincoln 225AC machine for about $150 or a used 225 AC/DC for about $250. Double those prices for new welders
  #123
Old 10-05-2012, 08:06 PM
Quote:
Just don't have a 220v outlet yet. Will though when I build my shop.
  #124
Old 10-06-2012, 09:25 AM
Got a washer and dryer?
  #125
Old 10-06-2012, 12:43 PM
fatdan460 fatdan460 is offline
fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.
or an electric stove? make an extension cord.
  #126
Old 10-06-2012, 09:12 PM
77mud's Avatar
77mud 77mud is offline
77mud has a very good reputation on FTE.77mud has a very good reputation on FTE.77mud has a very good reputation on FTE.
wire it straight into a coulple Extra breakers in your Panel box..... thats what i do when i need my stick welder...
  #127
Old 12-22-2012, 07:36 PM
1993_f350_2013's Avatar
1993_f350_2013 1993_f350_2013 is offline
1993_f350_2013 is gaining momentum as a positive member of FTE.1993_f350_2013 is gaining momentum as a positive member of FTE.
where did 9.ford.5 go
  #128
Old 12-22-2012, 07:50 PM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
How knows.
  #129
Old 12-23-2012, 09:15 AM
77mud's Avatar
Quote:
Originally Posted by hav24wheel View Post
How knows.
I think ya meant "who" there
  #130
Old 12-23-2012, 10:09 AM
hav24wheel's Avatar
Hmmm, at least I used all the right letters.
  #131
Old 12-23-2012, 03:51 PM
77mud's Avatar
that "smart" phone get's ya all the time.
  #132
Old 01-10-2013, 11:26 AM
them dang phones always do that to a guy
  #133
Old 09-26-2013, 06:39 PM
65sedandelivery's Avatar
65sedandelivery 65sedandelivery is offline
65sedandelivery is starting off with a positive reputation.
9.ford.5........cool swap! I am finishing the same swap on a 1984 short step side. I have been chatting with Alpha/Omega about some of the SASs that he has completed and the mounting of the 78-79 radius arm brackets on the 1984 frame. Mine measured out identical to yours. My front horizontal hole on my 78-79 radius arm brackets came out to be 4 7/8" behind the rear bolt of the factory TTB (well mine was a two wheel drive to start with). Your brackets look like about the same exact measurement as mine. I think I will have to notch my transmission cross member to clear the rear vertical bolt on the radius arm bracket. Alpha and others have done this swap and use the factory TTB radius arm bolt hole as the front bolt hole for the 78-79 bracket. I don't see anyway on my project of being able to move radius arm brackets 4 7/8" forward. I am working with a rolling chassis with stock springs. After I set the drivetrain in and body on I plan on using the 4" lift 78-79 c aftermarket coil springs. Right now with stock 78-79 springs and unloaded I have a 116 3/4 " wheel base. I was just wondering if you have any clue as to why mine and your radius arm mounts are so much farther back than some others? I don't guess it really matters as long as the tire is centered (I can't be positive with a cab/fender but have to be pretty close using the center of the 1984 coil spring bucket...Thanks for your pictures and information!!
  #134
Old 09-26-2013, 09:36 PM
kjett's Avatar
kjett kjett is offline
kjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to behold
Holy novel batman! Sometimes several short and to the point posts work much better to the low attention spans you'll find here
  #135
Old 09-27-2013, 04:42 PM
77mud's Avatar
Quote:
Truf i got threw about 2 lines before i lost interest and moved to the next post
4x4 PICTURES 9.ford.5 Offroad & 4x4 3204 07-21-2016 11:59 AM
1986 F150 money pit / trail rig / SAS 4 link '88_F-150 Offroad & 4x4 27 08-27-2011 02:48 PM
2 questions...oil leak and oil psi 300 I6... 9.ford.5 Ford Inline Six, 200, 250, 4.9L / 300 85 01-07-2010 12:02 AM
my SAS 9.ford.5 Offroad & 4x4 682 12-23-2009 03:48 PM
lets see your custom interiors 9.ford.5 1987 - 1996 F150 & Larger F-Series Trucks 37 06-10-2009 11:22 PM
Tags
88, 95, axel, axle, axleswap, bronco, disc, drum, f150, ford, kits, solid, straight, swap, truck, ttb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
