1/2 ton SAS (Solid Axle Swap) guide - Page 8 - Ford Truck Enthusiasts Forums
  #106
Old 10-04-2012, 07:46 PM
alpha/omega's Avatar
alpha/omega alpha/omega is offline
alpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to all
I can measure for you but i doubt my mount will be exactly the same as yours.
  #107
Old 10-04-2012, 07:51 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen ManfredVonRichtofen is offline
ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.
Quote:
I just checked on my Bronco. I have dual shocks on each side.
WTF is there to do now.
  #108
Old 10-04-2012, 08:00 PM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
You can run quad shocks, or leave two of the holes empty.
  #109
Old 10-04-2012, 08:03 PM
Quote:
Probably will run the quad since my 79 has quad on the front as well.
Now where will the track bar mount? I guess I will have to weld or bolt the track bar mount up to it then.
On my 79 the front shock tower has the track bar mount attached to it on the bottom.
  #110
Old 10-04-2012, 08:09 PM
Please do not take offense but im not sure you have the mechanical ability or a reading comprehension level necessary to pull this off by yourself
  #111
Old 10-04-2012, 08:10 PM
hav24wheel's Avatar
Usually on a SAS the trac bar bracket is more so under the frame
  #112
Naw, I just read to quick and don't pay attention.
  #113
Old 10-04-2012, 08:22 PM
Double postage.
  #114
Old 10-04-2012, 08:27 PM
In my thread the trac bar bracket is under the frame pretty much behind the driver side coil spring.
Do this...
1- Go to my thread, page 1
2- Right click on each of the install pics IN ORDER and then choose save as
3- Move all pics IN ORDER to a separate folder and view as a slideshow over and over until you see the process in your head.
4- Read the how to involved with each pic.
5- Gain knowledge, ask educated questions.
  #115
Old 10-04-2012, 08:32 PM
What thread was that?
Kiddin. I will look again but I didn't really knew I had dual shocks. Thought I had singles.
  #116
Old 10-04-2012, 08:40 PM
Forget about the duals. Its just a good reason to spend $100 extra on shocks.
  #117
Old 10-04-2012, 08:44 PM
10-4
Just keep the rear shock.
I think I could use my 79 front shock tower but cut it in half and use the bottom half of it and weld it to the frame...maybe have enough room if I want to ever put a front shock on it for the stock 90 coil bucket's front shock area.
  #118
Old 10-05-2012, 06:14 PM
_Hilljack_'s Avatar
_Hilljack_ _Hilljack_ is offline
_Hilljack_ is gaining momentum as a positive member of FTE.
almost had a 77 f150 that was in the process of being restored so it had everything i would have needed for my truck, but i was too late..
  #119
Old 10-05-2012, 07:03 PM
Also, forget about the factory track bar mount. Make one with a few points of contact
  #120
Old 10-05-2012, 08:36 PM
4x4 PICTURES 9.ford.5 Offroad & 4x4 3204 07-21-2016 12:59 PM
Coker Tire Spring Cruise In tacson 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 04-07-2013 01:17 PM
Danger Carts new accessory Ninelivez 1973 - 1979 F-100 & Larger F-Series Trucks 17 07-15-2012 01:12 AM
Just found some wires.... 1buckeyefan Excursion - King of SUVs 2 01-18-2011 02:29 PM
post your pics! 9.ford.5 Alberta Chapter 3 10-17-2009 10:18 PM
Tags
88, 95, axel, axle, axleswap, bronco, disc, drum, f150, ford, kits, solid, straight, swap, truck, ttb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
