1/2 ton SAS (Solid Axle Swap) guide - Page 7 - Ford Truck Enthusiasts Forums
  #91
Old 10-03-2012, 09:50 AM
_Hilljack_'s Avatar
_Hilljack_ _Hilljack_ is offline
_Hilljack_ is gaining momentum as a positive member of FTE.
So, Im going to be putting 79 F250 Axles in my 92 F150. After this is all said and done I was wondering what category I would look under for getting a lift kit for my truck. Would I look under 79 F250? or say 92 F350?
  #92
Old 10-03-2012, 01:37 PM
fatdan460 fatdan460 is offline
fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.
Quote:
hmmmmm, 79+92/2x4+4x4x4=327/4=81.75 so you should buy lift kit parts for an 81 3/4 ton truck. math makes everything so simple.
  #93
Old 10-03-2012, 01:47 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
go back to skool with your daughter meathead.
92-79= 13.
1/2 of 13 is 6.5
79+ 6.5= 85.5
so he needs lift kit parts for a 85 1/2 f-150 and a half
  #94
Old 10-03-2012, 05:46 PM
alpha/omega's Avatar
alpha/omega alpha/omega is offline
alpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to all
Are coilovers segregated by year?
  #95
Old 10-03-2012, 06:39 PM
i ain't rite
only in the southern states.
  #96
Old 10-03-2012, 06:41 PM
captain p4's Avatar
captain p4 captain p4 is offline
captain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud of
Are you retaining coils and radius arms or are you swapping the leaf springs from the 79 in as well?
  #97
Old 10-03-2012, 07:56 PM
_Hilljack_'s Avatar
Quote:
im planning on coils in the front, but swapping out the rear leaf springs (since f250 springs are heavier duty). I know I need to buy new coils up front that add at least 4" of lift.
  #98
Old 10-03-2012, 11:02 PM
Look at my sassy thread. Its a GED level how to
Use 79 suspension components
  #99
Old 10-04-2012, 10:58 AM
_Hilljack_'s Avatar
Wow! That was a great thread and I will probably follow it carefully. So are you saying that I should do coils? Or should i use the 250's leaf springs. From the research ive done most people prefer coils up front vs. leaf springs because the ride is smoother. And also my dad was telling me that i shouldn't use 250 axles because then my truck will be 8 lug instead of 5. What do yall think?
  #100
Old 10-04-2012, 11:10 AM
A 44 is a 44 is a 44. Doesnt matter 5 or 8 lugs the strength is exactly the same.
A 9" is basically the same in the strength department as a 60 rear so it would be a matter of preference and what matching set of axles you find...be it 5 or 8 lug.
It would be easier to use coils with a 5lug 44 front from a 73-79 150 but nothing wrong with leafs up front if you found a 44hd or 60 and matching 8 lug rear
  #101
Old 10-04-2012, 11:16 AM
_Hilljack_'s Avatar
Well i just talked to the guy selling the 79 and he won't move on the price so its back to square one trying to find one :/
  #102
Old 10-04-2012, 02:38 PM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
Find a 85.5-97 F350. Cheaper, and good axles under them.....
  #103
Old 10-04-2012, 06:22 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen ManfredVonRichtofen is offline
ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.ManfredVonRichtofen has a great reputation on FTE.
What is the length of your track bar mount from frame to the hole?
  #104
Old 10-04-2012, 06:27 PM
Quote:
Originally Posted by ManfredVonRichtofen View Post
What is the length of your track bar mount from frame to the hoe?
depends whether paul is in the stg or joppa
  #105
Old 10-04-2012, 06:31 PM
Quote:
LOL. I caught myself.
4x4 PICTURES 9.ford.5 Offroad & 4x4 3204 07-21-2016 11:59 AM
1986 F150 money pit / trail rig / SAS 4 link '88_F-150 Offroad & 4x4 27 08-27-2011 02:48 PM
2 questions...oil leak and oil psi 300 I6... 9.ford.5 Ford Inline Six, 200, 250, 4.9L / 300 85 01-07-2010 12:02 AM
my SAS 9.ford.5 Offroad & 4x4 682 12-23-2009 03:48 PM
lets see your custom interiors 9.ford.5 1987 - 1996 F150 & Larger F-Series Trucks 37 06-10-2009 11:22 PM
Tags
88, 95, axel, axle, axleswap, bronco, disc, drum, f150, ford, kits, solid, straight, swap, truck, ttb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
