1/2 ton SAS (Solid Axle Swap) guide - Page 6 - Ford Truck Enthusiasts Forums
  #76
Old 06-01-2012, 12:36 PM
alpha/omega's Avatar
alpha/omega alpha/omega is offline
alpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to all
Depends on the drop of your brackets but probably 4*
  #77
Old 06-01-2012, 12:41 PM
kid1994's Avatar
kid1994 kid1994 is offline
kid1994 is starting off with a positive reputation.
So what do i need to do?
Its a Rough Country lift just so you know
  #78
Old 06-01-2012, 12:46 PM
The ttb lift kit will not work on a sas.
Scroll down a little and read my sas thread
  #79
Old 06-01-2012, 12:51 PM
kid1994's Avatar
I know the lift kit wont work. I just wanted to use the radius arm drop brackets.
  #80
Old 06-01-2012, 12:55 PM
Dunnrightmobile Dunnrightmobile is offline
Dunnrightmobile is starting off with a positive reputation.
The radius arms work. I'm the the process of doing a swap on my 95 with a 77 axle.
  #81
Old 06-01-2012, 12:57 PM
Then use them. They will need to be moved back to just below the front cab bushing and modified to clear it
  #82
Old 06-01-2012, 12:59 PM
kid1994's Avatar
ok thanks for the help.
hey dunnrightmobile how is it going.
  #83
Old 06-01-2012, 01:11 PM
Its slow but its going can't wait till its done.
  #84
Old 06-01-2012, 01:13 PM
Sorry I ment the radius arm mounts work.
  #85
Old 06-01-2012, 01:14 PM
kid1994's Avatar
I havent started yet. But i cant wait eather. What problems have you had
  #86
Old 06-01-2012, 01:49 PM
For the most part its pretty simple. I can't believe that I paid 1200 $ for the lift kit before. The only thing hard about mine is I'm dropping the upper coil spring mount 2" for more lift. Just lining up the holes might be tricky
  #87
Old 09-19-2012, 12:54 PM
Seabee_Ford's Avatar
Seabee_Ford Seabee_Ford is offline
Seabee_Ford is starting off with a positive reputation.
I have and 8" lift on my truck currenty. Any idea what C bushing I will need?
  #88
Old 09-19-2012, 12:56 PM
7* and drop hangers probably. Thats a helluva lot of lift.
  #89
Old 09-19-2012, 05:36 PM
77mud's Avatar
77mud 77mud is offline
77mud has a very good reputation on FTE.77mud has a very good reputation on FTE.77mud has a very good reputation on FTE.
I put the drop brackets on my truck and it made the radius arms nice, but only had 4"
  #90
Old 09-19-2012, 08:24 PM
captain p4's Avatar
captain p4 captain p4 is offline
captain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud of
If you use drop brackets that are same size as the lift you shouldn't need degreed bushings if you're attempting to keep castor the same. Take the length of the radius arms, the size of the lift, and subtract from drop brackets. Draw a triangle, do some geometry and there you go.
4x4 PICTURES 9.ford.5 Offroad & 4x4 3204 07-21-2016 12:59 PM
Coker Tire Spring Cruise In tacson 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 04-07-2013 01:17 PM
Danger Carts new accessory Ninelivez 1973 - 1979 F-100 & Larger F-Series Trucks 17 07-15-2012 01:12 AM
Just found some wires.... 1buckeyefan Excursion - King of SUVs 2 01-18-2011 02:29 PM
post your pics! 9.ford.5 Alberta Chapter 3 10-17-2009 10:18 PM
Tags
88, 95, axel, axle, axleswap, bronco, disc, drum, f150, ford, kits, solid, straight, swap, truck, ttb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
