Box in the two pieces there to the frame. Imho I would get some pics of the bolt on bracket I've seen on a few trucks. Goes from engine crossmember to frame.
I have a question about the drag link. I know its porpuse is the keep the axle from moving side to side, but when the axle moves down from the the frame doesnt the drag link pull it the the drivers side.?
Sorry i know this is old but im about to do this swap.
i have a 1994 f1504x2 with a 6in lift and a donor 1979 bronco.
i wanted to know if i can use the 6in radius arm drop brackets from my 1994 f150?
Yes you can. I used the 79 drop brackets on my 95's frame. Just need to use the rear hole for the 94's brackets as the front and drill a new rear hole in the frame.
Edit, wait, are you using 94 ttb drop brackets or 79 radius arm brackets? Either way yes, just need to put them right for the correct radius arm.
