1/2 ton SAS (Solid Axle Swap) guide - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 11-23-2011, 08:15 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
Quote:
Originally Posted by bigredk8 View Post
awesome how would you go about reinforcing that?
Box in the two pieces there to the frame. Imho I would get some pics of the bolt on bracket I've seen on a few trucks. Goes from engine crossmember to frame.
  #62
Old 01-20-2012, 06:09 AM
Dunnrightmobile Dunnrightmobile is offline
Dunnrightmobile is starting off with a positive reputation.
I have a question about the drag link. I know its porpuse is the keep the axle from moving side to side, but when the axle moves down from the the frame doesnt the drag link pull it the the drivers side.?
  #63
Old 01-20-2012, 07:25 AM
kjett's Avatar
kjett kjett is offline
kjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to behold
It does, but its not noticable in most offroad situations. Usually only 1 wheel droops and not both at the same time where you'd really notice.
  #64
Old 01-21-2012, 08:13 PM
Is there any advantage to making the drag link mount as low as possible
  #65
Old 01-21-2012, 09:58 PM
Edgethis's Avatar
On the frame end? That would be bad I think as the lower the mount the longer the bar/bracket which puts more stress on it.
  #66
Old 01-21-2012, 10:16 PM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
You want the drag link and trac bar as close to parallel as possible to keep bump steer as low as possible.
  #67
Old 06-01-2012, 11:59 AM
kid1994's Avatar
kid1994 kid1994 is offline
kid1994 is starting off with a positive reputation.
Question
Sorry i know this is old but im about to do this swap.
i have a 1994 f1504x2 with a 6in lift and a donor 1979 bronco.
i wanted to know if i can use the 6in radius arm drop brackets from my 1994 f150?
  #68
Old 06-01-2012, 12:18 PM
alpha/omega's Avatar
alpha/omega alpha/omega is offline
alpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to all
As long as you use the ttb radius arm brackets, yes.
  #69
Old 06-01-2012, 12:19 PM
kjett's Avatar
Yes you can. I used the 79 drop brackets on my 95's frame. Just need to use the rear hole for the 94's brackets as the front and drill a new rear hole in the frame.
Edit, wait, are you using 94 ttb drop brackets or 79 radius arm brackets? Either way yes, just need to put them right for the correct radius arm.
  #70
Old 06-01-2012, 12:20 PM
I think the factory 73-79 radius arm brackets do a better job though
  #71
Old 06-01-2012, 12:24 PM
Karl, i think he wants to use the 94 drop brackets.
  #72
Old 06-01-2012, 12:25 PM
kid1994's Avatar
its the drop bracket from the ttd and they're thick and i like the way they look. i just wanted to make sure they would work
  #73
Old 06-01-2012, 12:33 PM
kid1994's Avatar
Also what C-bushings do I need?
  #74
Lets go with function first and looks second
  #75
Old 06-01-2012, 12:35 PM
kid1994's Avatar
True so what do you think?
4x4 PICTURES 9.ford.5 Offroad & 4x4 3204 07-21-2016 12:59 PM
2 questions...oil leak and oil psi 300 I6... 9.ford.5 Ford Inline Six, 200, 250, 4.9L / 300 85 01-07-2010 01:02 AM
my SAS 9.ford.5 Offroad & 4x4 682 12-23-2009 04:48 PM
lets see your custom interiors 9.ford.5 1987 - 1996 F150 & Larger F-Series Trucks 37 06-11-2009 12:22 AM
winter playing pics ! 9.ford.5 Offroad & 4x4 83 01-24-2009 09:08 PM
Tags
88, 95, axel, axle, axleswap, bronco, disc, drum, f150, ford, kits, solid, straight, swap, truck, ttb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
