Offroad & 4x4
1/2 ton SAS (Solid Axle Swap) guide
Old 06-07-2011, 08:04 PM
fatdan460's Avatar
fatdan460
fatdan460 is offline
Originally Posted by kjett
what did you buy? never know until you tell us...
x2 if you bought that super runner ttb setup crap (or whatever it's called) i think you are screwed, let us know what all you bought and is it installed or still in the boxes.
  #47
Old 06-07-2011, 08:16 PM
Danny93's Avatar
Danny93
Danny93 is offline
I got 4 ball joints... which i cant use. two moog tie rod ends and a moog drag link. also a steering stabilizer and a couple of skyjacker 8000 nitros.
  #48
Old 06-07-2011, 08:17 PM
Danny93's Avatar
Danny93
Danny93 is offline
and all are installed except for the stabilizer and shocks... going on this weekend
  #49
Old 06-08-2011, 09:50 AM
alpha/omega's Avatar
alpha/omega
alpha/omega is offline
None of that stuff will be used on a SAS swap on your truck. Well, maybe the shocks and its possible the steering stabilizer can be used. The tie rod and drag link will not work for certain.
  #50
Old 06-08-2011, 06:29 PM
Danny93's Avatar
Danny93
Danny93 is offline
bummer... o well... itll be a while anyway.
  #51
Old 09-01-2011, 04:53 PM
termin8ed's Avatar
termin8ed
termin8ed is offline
Has anyone cut the engine crossmember and plated it to reinforce it so you don't have to run a 4" lift?
just looking at it and it looks like I could gain a good 2-3 inches of clearance by trimming the ttb mounting section of the crossmember.
Not looking to do much offroading except for the dunes so I don't really need the flex and articulation.
  #52
Old 09-01-2011, 07:23 PM
fatdan460's Avatar
fatdan460
i've seen it done to a lot of trucks, but never without any lift. it's generally done by guys running 4'' lifts that are running into issues with the axle contacting the x member, so i'd say you are probably s.o.l. if you think you can go dune hopping with no lift and not have contact issues with zero lift.
  #53
Old 09-02-2011, 10:11 AM
termin8ed's Avatar
termin8ed
well, I guess when I say the dunes I wouldn't be jumping around. Just riding around and taking it easy with the family. got the jeep for dune hopping...
Either way it sounds like at least 4" of lift is the way to go.
  #54
Old 09-02-2011, 01:32 PM
alpha/omega
Ive never personally seen an 80-96 F150 with an SAS and less than 4" lift.
  #55
Old 09-13-2011, 12:24 AM
likeshills08's Avatar
likeshills08
likeshills08 is offline
Love this thread. Glad I finally found it. Sas on my 80 f100 is going together in the next week, its good because I don't have anything to refer to. I haven't grasped why I need a f350 drag link tho.
I have the stock one from the 79 bronco. Why can't that be used?
  #56
Old 09-13-2011, 01:40 AM
fatdan460's Avatar
fatdan460
^^^^sorry i don't have an answer for you on that and i'm not in the mood to search right now, but.......
i just reread this and i have a little tidbit to add for the guy who planned on using his ttb lift springs to do a sas or anyone else who plans to try it; don't do it.
the ttb springs are way the hell stiffer by design of the ttb axle and they won't flex worth a shyte with a mono beam axle. ttb springs are a heavier rate to accommodate the "wing action" of the ttb axle's movement and radius arm design. it might not make sense to some, but trust me, i read it on the interweb and i am an expert
  #57
Old 09-13-2011, 06:15 AM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
Stock link from 78-79 bronco has the wrong tapper to the pitman arm end of the drag link. Plus its the wrong length.
  #58
Old 11-23-2011, 06:28 PM
bigredk8's Avatar
bigredk8
bigredk8 is offline
http://i87.photobucket.com/albums/k1...Picture082.jpg
What is that bracket for? im assuming u had to custom fab it?
  #59
Old 11-23-2011, 06:57 PM
Edgethis's Avatar
Edgethis
Edgethis is online now
That's for the track bar.
  #60
Old 11-23-2011, 07:12 PM
bigredk8's Avatar
bigredk8
bigredk8 is offline
awesome how would you go about reinforcing that?
Quick Reply: 1/2 ton SAS (Solid Axle Swap) guide
