1/2 ton SAS (Solid Axle Swap) guide - Page 2 - Ford Truck Enthusiasts Forums
Old 07-14-2010, 01:49 AM
9.ford.5's Avatar
9.ford.5 9.ford.5 is offline
9.ford.5 is gaining momentum as a positive member of FTE.9.ford.5 is gaining momentum as a positive member of FTE.
junkyard had em actually...and 1/2 ton straight axle ford with discs will have them providing they havent already been scooped
Old 10-11-2010, 11:52 PM
jimbo beam's Avatar
jimbo beam jimbo beam is offline
jimbo beam is a splendid one to beholdjimbo beam is a splendid one to beholdjimbo beam is a splendid one to beholdjimbo beam is a splendid one to beholdjimbo beam is a splendid one to beholdjimbo beam is a splendid one to behold
Sorry to bring up an old thread, I just scored a complete 78 F150 D44 axle that I intend to hang on my 94 F150 and I have a couple questions.
If I read what you posted correctly you mentioned that the stock front driveshaft can be reused? My solid D44 has a slipyoke style pinion setup on it. So I can simply just swap the yoke off the ttb over to the solid axle and use the stock front driveshaft? There's no issues with the stock shaft being to short or anything with the truck lifted 4 inches?
I was also wondering about brake lines/flex lines. The setup on my D44 solid axle is a single rubber flex line off the truck, the rubber line goes into a junction block on the axle housing where it splits into two lines and goes out to the wheels. Will my stock 94 F150 ttb brake flex lines bolt to the 78 calipers? Or are different brake flex lines required?
Was also curious about the radius arm mounts. The mounts for my axle were cut in half by the idiot who removed the axle, I'm not having much luck finding stock 78-79 radius mounts, do you know of a online source for them?
Old 10-12-2010, 01:07 PM
alpha/omega's Avatar
alpha/omega alpha/omega is offline
alpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to all
I have no first hand knowledge on the d-shaft so I wont comment.
Im 99% sure you need to use the brake lines for a 78-79 D44 but again no first hand knowledge.
I do know JBG has the C-wedges http://broncograveyard.com/bronco/i-...rm-mounts.html
Old 10-12-2010, 02:00 PM
79Ford4x4's Avatar
79Ford4x4 79Ford4x4 is offline
79Ford4x4 is starting off with a positive reputation.
I cant seem to remember how the factory D44 solid's brakes were run. I would just use your factory setup all the way down to where it connects to the axle. Install a T centered on the D44 and hardline out to the knuckles. Then just a short flex hose to the calipers. I really dont like the setup with 2 brake lines running down to the axle. And IMO its not needed unless the truck has front ABS
I'm sure the master of D44 SAS will chime in here soon and give his "professional" opinion.
Old 10-12-2010, 02:36 PM
fatdan460 fatdan460 is offline
fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.
the factory setup was just one line running to the axle and teeing off to both calipers. as to calipers, i believe the banjo bolts are the same, but you might have to just undo your ttb's banjo bolt and try it in the solid d44's caliper to be sure. should fit just fine.
Old 10-12-2010, 04:50 PM
9.ford.5's Avatar
yes my TTB yoke went straight on the solid and the driveshaft fit fine with 4" lift.
the solid axles used a single drop setup and the "T" junction the IFS factory used a dual drop from the coil buckets to the calipers, i used that
Quote:
hey now, that was a dig
Old 10-21-2010, 12:08 AM
danger-ranger93's Avatar
danger-ranger93 danger-ranger93 is offline
danger-ranger93 is starting off with a positive reputation.
posting for subscription...
i know i can't spell..
Old 10-21-2010, 02:19 AM
9.ford.5's Avatar
ya know... i actually think you spelled it right lol. :P
Old 10-21-2010, 03:57 PM
Quote:
that just shows how bad i am at it... i didn't even know i spelt it right..
Old 10-21-2010, 04:07 PM
Prozon's Avatar
Prozon Prozon is offline
Prozon has a good reputation on FTE.Prozon has a good reputation on FTE.
Quote:
You spelled that wrong. xD
Old 10-21-2010, 04:34 PM
Quote:
oh hush... we have established i can not spell....
i have a serious question, this swap is pretty much exactly the same on a 4x2 correct?
i know i have to have a trans. and T-case also..
Old 10-22-2010, 01:09 PM
kjett's Avatar
kjett kjett is offline
kjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to behold
THe front axle portion is exactly the same from a 2wd to the 4wd. As you already know, with the exception of the transfer case.
  #28
Old 10-22-2010, 03:45 PM
Quote:
ok thanks, one more and im done until i actually do the swap, lets say i get everything i need to put the axle in and i get antsy and do it with out getting a 4x4 tranny and a T-case, should i experence any problems with it as far as driveability just running the D44 and it not hooked up?
i know that sounds dumb but i get excited sometimes and i can't help but jump in.. like the perry mud bog is this weekend, it has me all jacked up to get the swap done so i can have every kink, flaw, or iritation done so i can take my truck next year..
i may have to have a few of you beat me down to keep from starting on it...
  #29
Old 10-22-2010, 04:28 PM
Quote:
there are a few guys on here that are experts at beeating off, but i don't know about beating down
there shouldn't be any reason why you couldn't install the front axle ahead of time, least nothing is coming to mind why it wouldn't work. it'd be no different than driving a 4x4 around in 2x, just remember even if you swap to a ttb you will need to lift the rear a few inches with a block kit or an add a leaf.
  #30
Old 10-23-2010, 01:15 AM
i know, i have been looking at maybe a block and traction bars for the rear, as i start buying up parts i'll start a "build thread"
i'm thinkin of building my own traction bars for the rear, i know my little 302 isn't going to cause a lot of axle wrap but while i have it down and im working on it i might as well cover all points and be safe..
4x4 PICTURES 9.ford.5 Offroad & 4x4 3204 07-21-2016 12:59 PM
2 questions...oil leak and oil psi 300 I6... 9.ford.5 Ford Inline Six, 200, 250, 4.9L / 300 85 01-07-2010 01:02 AM
my SAS 9.ford.5 Offroad & 4x4 682 12-23-2009 04:48 PM
lets see your custom interiors 9.ford.5 1987 - 1996 F150 & Larger F-Series Trucks 37 06-11-2009 12:22 AM
winter playing pics ! 9.ford.5 Offroad & 4x4 83 01-24-2009 09:08 PM
Tags
88, 95, axel, axle, axleswap, bronco, disc, drum, f150, ford, kits, solid, straight, swap, truck, ttb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
