Offroad & 4x4
1/2 ton SAS (Solid Axle Swap) guide
Old 01-17-2014, 03:17 PM
country0001's Avatar
country0001
country0001 is offline
Just pick up a 44/9 out of a 79. Going to install in my 92. This has been very helpful so far.
  #137
Old 04-22-2014, 10:44 PM
dirtrider88's Avatar
dirtrider88
dirtrider88 is offline
ya thanks for the help
  #138
Old 10-30-2015, 12:54 AM
ferd_boy's Avatar
ferd_boy
ferd_boy is offline
SAS
Old post I know, but this was very helpful to me! Answered alot of questions at the right time as I plan on doing my SAS swap in my 87 f150 in the next 2 weeks! Axle is out of a 76 highboy, with disks, arb air locker, 4.09 gear, custom built long radius arms, and fully trussing the the d44 housing, and 6.5" lift springs. Never done a SAS swap bug can't wait to be sitting tall with a strait axle and 37's
18 longer that stock. And stronger!
  #139
Old 09-22-2018, 09:51 PM
Outlaw1989's Avatar
Outlaw1989
Outlaw1989 is offline
Im new to this type of thing and I know you used a 1975 axle. What I want to know is if this will work with a high pinion out of a 1977 model truck?
  #140
Old 09-23-2018, 03:05 PM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
yes, that’ll work. 75-78 front axles work.
  #141
Old 05-25-2020, 06:52 PM
General Lee's Avatar
General Lee
General Lee is offline
Question (s)
I have a 78 f150 4x4 w a dana 44 front. But is leaf spring and not coil. I have an 84 short wide I want to put it in... can I use this front axle or do I need to scrap it and by a completely different parts truck? I am planning on a 6 inch lift w 4 inch body to fit 36 13.50 currently but maybe larger down the road. If I can convert the 78 dana to coil how do i do that? Is there a kit i can buy that would ha e the majority of the parts i need in one shot? I don't know and this is my first sas. The 9 in the 78 is going in the same 84 as well, and the 429 cj on top of that.... lol i have all these thing but wrong type of suspension can i make it work? And what do i need thx
  #142
Old 12-16-2021, 09:30 AM
KubotaOrange76's Avatar
KubotaOrange76
KubotaOrange76 is offline
Its Comin Right for us!
Received 1,440 Likes on 937 Posts
What is the lowest anyone has successfully run a sas? 4" over stock ttb height??
Searching forums for this info is much much harder than it was 10 yrs ago now that vertical scope has ruined FSB and pirate
I have had a complete 79 swb frame with axles and drivetrain for a few years now. Before I scrapped the body I had rebuilt the rear axle with a spool, new bearings/seals etc. Front axle was gone thru also with full circle clips and life series joints etc. I want to make my 89 4x4, but I prefer it to be as low as possible. Ideally just be about 2" over stock ttb 4x4 height.
Starting to lean towards a ttb setup. I want to run 33's with 3.50 gears being I have and intend to keep a c6.
Thoughts?
  #143
Old 12-16-2021, 11:35 AM
_Hilljack_'s Avatar
_Hilljack_
_Hilljack_ is offline
Thoughts?
From all the research I did prior to doing my SAS 4” was the minimum lift required in order to clear the cross member. Granted that’s been probably 8 years ago or so but that number stands out.
The following users liked this post:
  #144
Old 01-15-2022, 03:39 AM
92coyoteBRONCO's Avatar
92coyoteBRONCO
92coyoteBRONCO is offline
Thoughts?
I must say, about 90% of you need to go to the top and read beginning to end. ****....some probably need to read it 2-3 times. Then out of that 90%, 3/4 of you need to just forget about doing a SAS and worry about learning how to check your tire pressure and doing oil changes first. Now, those who read the thread from the beginning wont have to ask the same ****ing questions over and over and over. You ask a question and then ****ing argue about the answer given to you. No you can't use a 78-79 drag link on a sas. It DOES NOT FIT. ****. You need one from 92 up F-350. Quit asking why and what if and how come. You want to use your old one and save money? Go ahead. IT DONT FIT!!!! What is minimum lift? 4 INCHES!!!!!! Can you go less? Why not? How come? YOU CAN, GO RIGHT AHEAD. USE YOUR STOCK COILS!!!! ANYBODY TELLING YOU IT DOESN'T WORK BECAUSE OF CLEARANCE DOESN'T KNOW WHAT THEY ARE TALKING ABOUT. Why do you need to fab a Trac bar mount? WELL, FOR THE 86TH TIME, YOU DONT. YOU CAN BUY AFTERMARKET FOR SAS. Fabbing your own is only to save you from paying a million dollars for one. Everyone asks the stupidest questions over and over expecting a different answer they want to hear. Some of the questions like can I run 44's on a ttb dana 44? Yes. Go ahead. You going to break ****. Then the same guy that asked that question has a smart *** answer like " How about if I run 42's then? My cousins neighbor had 42s on his Ford. Well dip **** he also a ****in F350 with a dana 60 on that Ford with 42s. I cant believe some of you retards.
  #145
Old 01-15-2022, 07:25 AM
KubotaOrange76
RonaldN0519
113
02-02-2022 03:05 PM
BillyBob69
08-04-2021 10:14 AM
9.ford.5
Offroad & 4x4
3219
01-04-2021 07:52 PM
BIGDZL
6.7L Power Stroke Diesel
115
04-25-2016 07:54 AM
EarlyCobra
11-12-2015 06:45 AM
Quick Reply: 1/2 ton SAS (Solid Axle Swap) guide
