1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Immediate loss of power then transmission slip
Old 10-06-2009, 10:04 PM
preparation_h's Avatar
preparation_h
preparation_h is offline
1999 F250 V10.
I was going up I70 in the rockies this last weekend with the overdrive OFF and all of the sudden the engine seemed to completely lose power, then the tranmission started slipping. This occured for about a minute. I then put the truck back into overdrive and all the symptoms disappeared. Anybody have any idea of what happened? I haven't had the truck for that long, but have never felt anything like this in any vehicle?
Thanks in advance,
Chris.
Old 10-06-2009, 10:11 PM
bill11012's Avatar
bill11012
bill11012 is offline
Modular motor junkie
Any trouble codes?
Is it full of clean fluid?
Was it a shudder through the whole truck, or like it was in neutral?
Did the OD lock out light blink?
Old 10-06-2009, 10:13 PM
EXv10's Avatar
EXv10
EXv10 is offline
Hopefully it wasn't trying to lock up in that gear. I wouldn't drive it until I had it looked at. Check your fluild...see if it's burnt.
Old 10-07-2009, 04:34 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,570 Likes on 1,049 Posts
Wasn't trying to lockup in what gear? The 4R100 is capable of locking in all four forward gears.
It might be an electrical power problem to the Powertrain Control Module (PCM.)
Old 10-07-2009, 12:16 PM
EXv10's Avatar
EXv10
EXv10 is offline
I meant locking between 2 gears. A malfuntion that would cause loss of power and slippage. (Trying to get into 2 gears at the same time).
Old 10-07-2009, 10:11 PM
preparation_h
no trouble codes
no flashing OD light.
I haven't checked the transmission fluid. It hasn't happened since.
I think it might have something to do with the superchip that I had installed on the car.
Old 10-07-2009, 10:46 PM
bill11012's Avatar
bill11012
It may just be a coil, I have known several people that though they a bad tranny and it was a misfire.
You need to check the fluid, But if it is ok i would not worry about it.
Old 10-08-2009, 05:28 AM
Mark Kovalsky
This is a non-synchronous transmission. It can't do that.
Old 10-08-2009, 10:58 AM
EXv10's Avatar
EXv10
EXv10 is offline
So some can and some can't?
Old 10-12-2009, 12:26 PM
Mark Kovalsky
Yes, a transmission that is a synchronous shift can try to engage two gears at once. Bad things happen. It's not possible on the 4R100.
eyball
1983 - 2012 Ranger & B-Series
32
05-26-2014 02:51 PM
jc2
12-28-2006 06:01 AM
81-87-93.ford
1978 - 1996 Big Bronco
03-24-2006 12:50 PM
MisterCMK
1997-2006 Expedition & Navigator
03-23-2003 12:13 AM
chris93
03-10-2003 07:30 AM
Quick Reply: Immediate loss of power then transmission slip
