alternator would not affect the ignition system in your case. check the codes first. about the coil. You say it's intermittent - if it seems to misfire at high humidity check for "loose" sparks under the hood. They are clearly seen at night w/o any light source around. If any, clean the coil body, the wires etc. this could help for a while.
