This is only an idia. But I've been reading latley that a lot of strange things happen due to loose battery connections. These could be at the battery itself or the other end of the main battery cables. I think there is a seperate ground cable from engine to chassis. What you described sounds like the radio lost memory that one time and then your info. center lost memory and then went back to default. Also I remember reading on here that water or moisture had been known to get through the firewall and travel into the fuse panel and corroding connections in there. Like I said, just a couple of ideas. Let us know what you found if anything.
__________________
 2007 F150 XLT SCREW 4 X 4, 5.4, 3.73 LIMITED SLIP, TOW PACKAGE. CHROME DOOR HANDLES TRUXEDO TONNEAU COVER, TTT TOW MIRRORS.
"I would rather push a Ford than drive anything made by GM."
