Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-06-2009, 10:42 AM
kvl123 kvl123 is offline
kvl123 is starting off with a positive reputation.
gross vehicle weight rating?
Hi
I have a 1980 F250. How do you find out the gross vehicle weight rating (GVWR) if the sticker in the door has been removed?
Thanks much!
  #2 (permalink)
Old 10-06-2009, 10:47 AM
senix's Avatar
senix senix is offline
senix has a very good reputation on FTE. senix has a very good reputation on FTE. senix has a very good reputation on FTE.
you may be able to call ford customer service and see if they can send you the door stickers.
worth a shot.
__________________
Scott-2008 F250 PSD Crew Cab 4x4, X-liner,
Cooper Discovery STT LT275/70R18's
Skyjacker dual steer stabilizer
Banks Ram Air & 6-Gun, Ravelco Alarm System, Frontier Extreme FT. Bumper
  #3 (permalink)
Old 10-06-2009, 02:57 PM
jorlee jorlee is offline
jorlee is starting off with a positive reputation.
Here's what I would do. Take one tire's weight rating and multiply it by four. That would be what you could legally haul. But, most vehicles are rated way less than the tires rating. So you couple probably take 10-15% off of the tires max, and should be pretty close.
Hopefully someone who owns a similar vehicle will tune in.
__________________
Jordan
2006 F250 6.0 4x4
Ranchhand GG, Weathertech FL, VS; Access Toolbox Edition, PTO (elevated idle 1200 RPM) Idle Mod via Upfitter switch (not high idle)
I abuse my Ford, and it asks for more.
  #4 (permalink)
Old 10-06-2009, 03:30 PM
Furian's Avatar
Furian Furian is online now
You Keep What You Kill
Furian has a good reputation on FTE. Furian has a good reputation on FTE.
Have you checked the Owner's Manual?
__________________
Andrew
2005 F-350 4X4, Regular Cab Long Bed, XL Package, 5.4L 3V Engine, TorqShift®, 4.10 Limited Slip, K&N CAI Kit, SCT Livewire w/ Custom Tunes from 5 Star Tuning
  #5 (permalink)
Old 10-06-2009, 04:13 PM
brian42's Avatar
brian42 brian42 is offline
brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE.
Ford.com only goes back to 1996 for on-line copies. I would call Ford Customer Service and ask them. They were able to send me a build sheet for my VIN. Short of trying to find an old owner's manual on eBay or Craigslist, they would know how to find out your info.
__________________
THE MOOSE
2003 F-250 PSD 7.3 Lariat FX4 CC/SB, 4R100, 3.73LS, dual alternators with 195K+ Miles
AIH delete, In-Tank and Harpoon Mod, SS HPX, 203F Thermo w/Billet Housing, FTVB, '08 Rear Diff Cover, Headlight Harness, Zoodad, 6637, Foil Delete, Engine/CAC boots, Moog Ball Joints, BFG Mud-Terrain TA KM2 285/75-16
I can't decide which I like most about my truck...the noise or the smell.
  #6 (permalink)
Old 10-06-2009, 04:18 PM
thanks for the info folks
  #7 (permalink)
Old 10-06-2009, 04:51 PM
Furian's Avatar
Rock On kvl123!
__________________
Andrew
  #8 (permalink)
Old 10-06-2009, 04:58 PM
beached350 beached350 is offline
beached350 is starting off with a positive reputation.
Call your insurance company, they can do a search on the vin which will provide the gvwr or a gvwr range.
  #9 (permalink)
Old 10-06-2009, 07:46 PM
Kenworth Kenworth is offline
Kenworth is starting off with a positive reputation.
It all depends Ford offered the F-250 as a light duty and heavy duty model.
If your truck has the semi floating rear axle I think the gvw is 6800lbs if its the HD truck it has a 8000lb gvw. The rear axle in the HD has the 10.25 or the Dana 60.
Tags
2003 , 2009 , f250 , f350 , find , ford , gcvw , gross , gvw , gvwr , ratings , truck , vehicle , weight , weights
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
