Go Back   Ford Truck Enthusiasts Forums > Misc. > Paint and Bodywork
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Paint and Bodywork SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-05-2009, 10:34 PM
7mag 7mag is offline
7mag is starting off with a positive reputation.
Bed Liner on rocker panels
Has anyone ever done their rocker panels with a bed liner type coating? I have wanted to do it to mine but Im not sure if I should attempt it or have a professional do it. What are your experiances? Whats involved? Anyone know how much I could get it done for professionally?
Thanks
Kirk
  #2 (permalink)
Old 10-05-2009, 11:52 PM
Chaosracing Chaosracing is offline
Chaosracing is gaining momentum as a positive member of FTE.
If done properly, it will last a long time. Prep is the important part in this step. You will need to sand the areas with at least 36 grit paper, clean the areas real good with a wax and grease remover, mask off the area and then apply per manuf instructions. But if you are looking for a smooth finish, you wont get it with bed liner.
__________________
2002 Ford F250 4x4 V10<-FORD's best kept secret.
1947 Ford 1 Ton
2001 Sport Trac (Wife's vehicle)
Powered by Ford, Fueled by Madness
Support America and capitalism....BUY A FORD!!!!
  #3 (permalink)
Old 10-11-2009, 03:14 PM
big_ford_rednek's Avatar
big_ford_rednek big_ford_rednek is offline
big_ford_rednek is starting off with a positive reputation.
it looks awesome.and is tough as nails. my 89 is covered up to the body line just below the window with it. two thumbs up
__________________
1995 Ford F150 300 6cyl (soon to be 351w/zf5 spd) 4x4
http://www.ford-trucks.com/user_gall...id=206330&.jpg
  #4 (permalink)
Old 10-25-2009, 12:42 AM
gt350h gt350h is offline
gt350h is starting off with a positive reputation.
I would maybe go with 80 grit instead. 36 will probably sand down to bare metal in spots and bedliner is so textured sometimes you won't get every single thing 100% covered. 80 is plenty of grip and you probably won't go through. I agree though, its all in the prep with bedliner. And it will last a long time.
  #5 (permalink)
Old 11-05-2009, 12:15 AM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4 78_f800crewcab4x4 is online now
78_f800crewcab4x4 is gaining momentum as a positive member of FTE. 78_f800crewcab4x4 is gaining momentum as a positive member of FTE.
Quote:
If it is not 100% covered, it may not be applied right. herculiner needs two coats, and its 100% coverage and waterproof.
__________________
1978 F600 Bronco 4 door "Centurion"
1958 F700 next "Centurion" project
1973 F350 Crew Cab Special, 460 all race
2002 Excursion Limited 4x4 7.3
Please help them:
http://www.lionconservation.org/index.html
  #6 (permalink)
Old 11-05-2009, 02:51 AM
I was assuming a spray on application. Herculiner is waterproof, but there's some important things it is not. It is not catalyzed, which means if you spill gas on it, it will melt right off. Also, not being catalyzed (using hardener) it is not UV stable. Which is why almost every Herculiner job that you see that is exposed to sunlight chalks out very badly a year or two later. I've used "Hippo Liner" or "Shake and Shoot" by Dominion Sure Seal and they're great products. SEM makes one too, as do a ton of other brands. I'd definitely get one that takes a hardener though.
Tags
1965 , 1997 , 2004 , bed , bedliner , coat , f100 , f150 , ford , liner , paint , panel , panels , rocker , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
