'05 Sport Trac center arm rest
the center arm rest on my '05 Sport Trac collapsed. There is no support in the front for this thing, just the rear. Has anyone resplaced one themselves? I can't find how it attaches to the rear mount. Anyone with advice? the Dealer wants $175 to replace including labor, which seems real high to me. can i order a replacement somewhere on line??
thanks
thanks
From your description I'm thinking you have the short console, the one with the bag. There is a repair plate available on ebay, haven't tried it myself.
]FORD SPORT TRAC CONSOLE REPAIR KIT 95 96 97 98 99 01:eBay Motors (item 140345236548 end time Oct-10-09 12:41:02 PDT)
If it's the hinge that broke it can be repaired with this. It's not exactly like the Trac piece but it fits fine.
]1989-90 FORD BRONCO II New Console Arm Rest Bracket TAN:eBay Motors (item 370195586657 end time Oct-27-09 19:30:04 PDT)
I actually have an older Explorer arm rest on mine right now until I decide what repair route to take.
Here's the older Explorer/Bronco II comparison to the Trac model:
This is what the arm rests attach to, under the plastic console:
This shows the Explorer/Bronco II arm rest installed on my Trac's console. It's a bit shorter and slightly a different color but it works for now. The mounting bolts are accessed by removing the oblong cover visible in the photo. Attaching bolts require a 8MM or 5/16" socket on an extension to remove them:
Spades
04-04-2017 12:14 PM
Adrenalin9699
02-11-2016 08:46 PM
adth1234
07-07-2011 05:55 AM
