2003 6.0L Tow/Haul Lights Flashes - Ford Truck Enthusiasts Forums
Old 10-05-2009, 02:02 PM
Freedom0115 Freedom0115 is offline
Freedom0115 is starting off with a positive reputation.
I have a 2003 F350 Crew cab DRW 6.0L Diesel. I have been experiencing problems with the trans all summer. It seems the tow/haul light starts flashing and at that point the trans starts shifting irregularly. Such as starting off from a dead stop, the trans will be in 2nd gear or at higher highway speeds it doesn't down shift as it should when calling for more acceration... All of this only gets worse if I tow my boat. So far we have changed out the shift solinoids with still no luck..
Can anyone help?
Old 10-05-2009, 02:54 PM
l-m tech l-m tech is offline
l-m tech is gaining momentum as a positive member of FTE.
what code are you getting
Old 10-05-2009, 03:28 PM
Just the " Keep Alive Memory" which I had reset at the dealer.
My friend from the dealership is bringing the Ford scan tool over tonight and we are going to check it again.
Old 10-05-2009, 06:18 PM
dcaddi2's Avatar
dcaddi2 dcaddi2 is offline
dcaddi2 is gaining momentum as a positive member of FTE.dcaddi2 is gaining momentum as a positive member of FTE.
With the tow/haul light flashing, you'll have tranny related DTC, that sure will lead you to the source of the problem....I'm sure the Ford scan tool will pick it up.
Old 10-05-2009, 08:37 PM
ljutic ss's Avatar
ljutic ss ljutic ss is offline
ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.
I had a similar problem with mine in the spring, my fix was the TFT sensor in the trans was bad. It would run fine for a mile or 2 then the trans temp gauge on the dash would bury hot and I would start getting the weird shifts. If this is your problem, it's a very easy fix.
Old 11-02-2009, 07:51 PM
Well the trans codes are as follows... Hope someone can help me here..
P2703
P0730
Old 11-02-2009, 07:52 PM
Code P2703 and P0730
Old 11-02-2009, 11:36 PM
topdrive topdrive is offline
topdrive is starting off with a positive reputation.
p2703 -Transmission friction element d apply time range/performance
p0730-incorrect gear ratio
i dont no if that helps im lost when it comes to trannys good luck
Old 11-03-2009, 04:45 AM
dcaddi2's Avatar
Quote:
Now, this is not good. Even though these codes could be related to a faulty shifting solenoid, but a solenoid usually have it's "own" DTC.
I've had symptoms as you have, and I've had gear ratio and friction element codes, and I ended up rebuilding my tranny......
Old 11-03-2009, 02:42 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Freedom....are you running a tuner on the truck?
Old 11-03-2009, 03:14 PM
I was running a Bully Dog Power PUP.... since this problem has occured I removed everything and put it back to stock.... The programer only elevated the symptoms even worse..
Old 11-03-2009, 04:26 PM
firemanpat29 firemanpat29 is offline
firemanpat29 is starting off with a positive reputation.
transmission. (transmission is shot!!!!!!!!)
Old 11-03-2009, 05:50 PM
dcaddi2's Avatar
What do you mean it shifts irregularly? Is it slipping?
I understand that it gets stuck in 3rd gear at a stop. Do you have any symptoms in reverse? I'm asking, because the week part of the 5r110 transmission is the direct clutch, and if you have a problem with that, it will get stuck in 3rd gear sometimes, you also will notice slipping between 3-5th gear, but it also will act weird in reverse ( delayed engage, shaking ).
Anyways, the bottom line is, you got friction DTC-s, and you mentioned that you drove the truck like that all summer long - and towing a boat, so I believe that you will facing a tranny rebuild. If you like the challenge, you could do it yourself, but I'll tell you by experience, that it's one of the hardest jobs on the 6.0 - mostly because dropping and reinstalling that heavy beast. But it's still doable, and if you decide not paying about $2500-3500 on labor I highly recommend getting a torqueshift rebuild manual - you can find'em on ebay.
For the time being you could try replacing the fluid, but i doubt that will help.
Old 03-10-2014, 08:29 AM
03powerstrokefl's Avatar
03powerstrokefl 03powerstrokefl is offline
03powerstrokefl is starting off with a positive reputation.
P2703
P0730
My truck is doing the same thing and still haven't figured it out. But I replaced the trans temp sensor and it didn't help out.
Old 03-10-2014, 09:12 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Quote:
What codes did you have stored?
2003 Auto Tranny codes tjustice 6.0L Power Stroke Diesel 1 02-02-2016 04:40 PM
05' F250 6.0L 5r110 Trans Issue titusf350 1999 to 2016 Super Duty 2 05-12-2015 01:05 PM
Problems after driving with dead batteries gharris54 6.0L Power Stroke Diesel 3 07-11-2014 05:19 PM
Yes Another TFT question 2004 6.0 shift problems PLEASE HELP drtyhatch 1999 to 2016 Super Duty 5 09-25-2011 07:35 AM
Hard downshift in Tow/Haul 2003PSDF2504x4 1999 to 2016 Super Duty 9 09-23-2007 10:02 PM
Tags
2003, 2004, 2005, 250, 60l, code, dtc, f250, f350, flashing, ford, haul, light, p2703, problems, shift, tow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
