351w wont start
351w wont start
Well the long trek to get this truck going again with a few more ponies is turning into a real headache. Everythings in and attached correctly. Grounds are good. Fuel pressure is 40 psi. It is getting spark. The motor turns over and acts like it wants to start, but will only fire a few times and not run. What am I missing? Took the #1 piston to TDC and the rotors right where #1 wire is and the balancer says 0*. try starting it and nothing. Turn it over and move the distributor left or right slowly, nothing. I dont know whats going on!!!!!! please help
I have a 74 351w block bored .040 over. Stock intake and plenum and a stock bottom end. The heads are Gt40s with 1.7 RR in them and Flowtech LTs on them. The cam is a crane 444232 cam and the same as the origional firing order I believe as it was for the 351w?
The valve lash is the adjustment on the rockers to ensure that the valves are not being held open very slightly on the compression stroke.
If the valves are held open, however little, the engine will have no compression on those cylinders.
You have double checked the firing order and that the dist is in right and I don`t think the fuel pressure is the problem.
running out of ideas.
No, if you torqued them down properly you should be OK.
You seem to have done everything right. As mentioned in a previous post the firing order for the 351 is not the same as the 302. Have you got a manual with the right firing order shown?
You say you have spark. Did you check the spark with the plug set on the engine or the spark at the coil.
Did you check the inside of the dist cap for cracks?
