Carrier bearing install
Old 10-05-2009, 10:38 AM
RussB's Avatar
RussB
RussB is offline
Do you guys no if there's any tricks to installing a carrier bearing or a steady bearing.. whatever you want to call it ! Is it a pretty straight forward install ?? Also I have a 4" lift. What kind of a shim do I need to put in it ??
Thanks Russ
Old 10-05-2009, 02:26 PM
big poppa's Avatar
big poppa
big poppa is offline
I know they have to be pressed out, the old bearing, sorry I can't be of more assistance, had mine done at a shop.
Old 10-05-2009, 08:30 PM
RussB's Avatar
RussB
RussB is offline
Yup they do have to get pressed out ! Found that out ! Going to pull the drive shaft when I get back home and take it in to a shop to get pressed on and off !
Old 10-05-2009, 09:04 PM
green 69's Avatar
green 69
green 69 is offline
carrier bearing
I just had bought a shim kit, it states to install a 1/4" shim for every inch of lift.. I belive the shim kit cost me 30 bucks,
I had a shimmy at take off this is what they said would help that problem, also knows as axel wrap, due to the high tourqe of the diesel.
hope this helps
Old 10-05-2009, 09:31 PM
schmuly's Avatar
schmuly
schmuly is offline
I changed mine about 3 weeks ago. Did not have to get it pressed off, I used a big gear puller, and it slid off. I did have a problem getting the nut off it is either IIRC 2 and 3/16 or 33mm a 1/2 " impact could not budge it so I took it in and they used a 3/4 " impact to get it off. Yours should be easier than mine ....less milage. 228k now
Colin
Old 10-05-2009, 11:23 PM
Meeks's Avatar
Meeks
Meeks is offline
Think the quarter inch thing is right. Mine came with a two inch square tube. Installed it and no more vibration taking off.
Old 10-06-2009, 12:21 AM
RussB's Avatar
RussB
RussB is offline
So I can use anything to space that down the appropriate amount then ???? ie piece of alluminum or steel ????
Old 10-06-2009, 05:52 AM
Meeks's Avatar
Meeks
Meeks is offline
yeah! It's just two bolts that hold it on. Get you a quarter inch piece of steel plate and cut it out in a rectangle to match the top of your carrier bearing. Drill a couple holes and your done. Only thing is you might have to get longer bolts and mine came with grade 8 bolts which I wouldn't use anything else.
Old 10-06-2009, 10:05 AM
RussB's Avatar
RussB
RussB is offline
Thanks... sounds easy enough !
Old 10-06-2009, 10:08 AM
mongo75's Avatar
mongo75
mongo75 is offline
If you can't get it pulled off, you can also CAREFULLY cut it off with a cutting wheel, and CAREFULLY beat the new one on. But like the others said, it should be done by a shop.
Old 10-06-2009, 10:50 AM
Want-A-Be 7.3's Avatar
Want-A-Be 7.3
Want-A-Be 7.3 is offline
Another note: be sure to lube the splines on the shafts really well, this will help in the drive line thump when starting and stopping.
PS The service call it a support bearing, the differential have carrier bearings I think.
351Cleveland C4
08-11-2014 02:44 PM
LeoJr
12-31-2013 09:30 PM
84-250
76
06-05-2013 05:58 AM
nomad221
05-29-2012 01:24 AM
powerstroker100
1999 to 2016 Super Duty
11-01-2011 08:04 PM
Quick Reply: Carrier bearing install
