Carrier bearing install - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 10-05-2009, 11:38 AM
RussB's Avatar
RussB RussB is offline
RussB has a good reputation on FTE.RussB has a good reputation on FTE.
Do you guys no if there's any tricks to installing a carrier bearing or a steady bearing.. whatever you want to call it ! Is it a pretty straight forward install ?? Also I have a 4" lift. What kind of a shim do I need to put in it ??
Thanks Russ
Old 10-05-2009, 03:26 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
I know they have to be pressed out, the old bearing, sorry I can't be of more assistance, had mine done at a shop.
Old 10-05-2009, 09:30 PM
RussB's Avatar
Yup they do have to get pressed out ! Found that out ! Going to pull the drive shaft when I get back home and take it in to a shop to get pressed on and off !
Old 10-05-2009, 10:04 PM
green 69's Avatar
green 69 green 69 is offline
green 69 is starting off with a positive reputation.
carrier bearing
I just had bought a shim kit, it states to install a 1/4" shim for every inch of lift.. I belive the shim kit cost me 30 bucks,
I had a shimmy at take off this is what they said would help that problem, also knows as axel wrap, due to the high tourqe of the diesel.
hope this helps
Old 10-05-2009, 10:31 PM
schmuly's Avatar
schmuly schmuly is offline
schmuly is starting off with a positive reputation.
I changed mine about 3 weeks ago. Did not have to get it pressed off, I used a big gear puller, and it slid off. I did have a problem getting the nut off it is either IIRC 2 and 3/16 or 33mm a 1/2 " impact could not budge it so I took it in and they used a 3/4 " impact to get it off. Yours should be easier than mine ....less milage. 228k now
Colin
Old 10-06-2009, 12:23 AM
Meeks's Avatar
Meeks Meeks is offline
Meeks is starting off with a positive reputation.
Think the quarter inch thing is right. Mine came with a two inch square tube. Installed it and no more vibration taking off.
Old 10-06-2009, 01:21 AM
RussB's Avatar
Quote:
So I can use anything to space that down the appropriate amount then ???? ie piece of alluminum or steel ????
Old 10-06-2009, 06:52 AM
Meeks's Avatar
yeah! It's just two bolts that hold it on. Get you a quarter inch piece of steel plate and cut it out in a rectangle to match the top of your carrier bearing. Drill a couple holes and your done. Only thing is you might have to get longer bolts and mine came with grade 8 bolts which I wouldn't use anything else.
Old 10-06-2009, 11:05 AM
RussB's Avatar
Thanks... sounds easy enough !
Old 10-06-2009, 11:08 AM
mongo75's Avatar
mongo75 mongo75 is offline
mongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to all
If you can't get it pulled off, you can also CAREFULLY cut it off with a cutting wheel, and CAREFULLY beat the new one on. But like the others said, it should be done by a shop.
Old 10-06-2009, 11:50 AM
Want-A-Be 7.3's Avatar
Want-A-Be 7.3 Want-A-Be 7.3 is offline
Want-A-Be 7.3 is starting off with a positive reputation.
Another note: be sure to lube the splines on the shafts really well, this will help in the drive line thump when starting and stopping.
PS The service call it a support bearing, the differential have carrier bearings I think.
How do i grease the carrier bearing? 351Cleveland C4 1967 - 1972 F-100 & Larger F-Series Trucks 8 08-11-2014 03:44 PM
Dana 60 bearing replacement without setting up backlash? LeoJr 1987 - 1996 F150 & Larger F-Series Trucks 3 12-31-2013 10:30 PM
Killing carrier bearings 84-250 1994.5 - 1997 7.3L Power Stroke Diesel 76 06-05-2013 06:58 AM
10.25 rear end carrier bearings / races nomad221 1994.5 - 1997 7.3L Power Stroke Diesel 14 05-29-2012 02:24 AM
how to replace carrier bearing powerstroker100 1999 to 2016 Super Duty 3 11-01-2011 09:04 PM
Tags
2003, bearing, bearings, carrier, drill, dually, f250, f350, f650, ford, install, installing, removal, shimmy, vibrates
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
