Air bag light, no horn, no cruise?? - Ford Truck Enthusiasts Forums
Old 10-05-2009, 08:23 AM
mustange70's Avatar
mustange70 mustange70 is offline
mustange70 has a good reputation on FTE.mustange70 has a good reputation on FTE.
Just wondering if this is gonna be an easy fix or not, as i don't have a lot of spare time to take the truck in to get warrantee to take care of it.
The problem:
About 3 weeks ago i was at a mud bog working on my broken race truck, and my 08 f-150 (4x4 ext. cab with the 5.4) dies on my when i go to start it, it just conks out when i go to start, ends up being the battery, as it was stone dead and wouldn't take a charge either, so i quickly change the battery with a spare i carry when i'm racing.
Anyway shortly thereafter (i think its that same day or the following day) the air bag light light starts turns on, but theres no warning sounds as the owners manual would indicate if there was a major problem. Then on my trip down to the family farm this friday i notice that the cruise control won't turn on, and when i went to lay on the horn to ward off a fastly approaching deer i come to discover that it isn't working either.
Now all these problems to indicated that it was a steering column problem and i proceded to check for burnt fuses (as i did use the truck to jump start the race truck so i thought i may have done something there), but in my short period of checking i didn't find anything, but i didn't check everything.
So anyone have any ideas that i could quickly check, a burnt fuse or bad relay, or a unconnected electrical connector by chance? I do have the ability to check codes as i do have a hypermax programmer that can pull any codes.
Old 10-05-2009, 12:38 PM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold
It sounds like the symptoms of a bad clock spring to me.
__________________
Like us on Facebook
SHOP HERE FOR AWESOME BRAKE PAD AND ROTOR KITS - FREE SHIPPING
Old 10-05-2009, 09:15 PM
nascar88ford nascar88ford is offline
nascar88ford is starting off with a positive reputation.
x2 on the clockspring
Old 10-05-2009, 09:35 PM
mustange70's Avatar
the air bag light is flashing code 19. Whats the clockspring and how is it replaced/fixed?
Old 10-05-2009, 09:44 PM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
F150 clockspring - Google Product Search
Your exact clock spring may look different.
Disconnect the battery.
Wait at least a half hour.
Always wait for power to drain to avoid premature airbag deployment!!
Remove the airbag pack from the steering wheel
Remove the steering wheel
Remove the lower column shroud
Disconnect the wiring for the clock spring
Remove the clock spring from the column
Reverse the process to install clock spring
Old 10-05-2009, 10:07 PM
mustange70's Avatar
thanks a bunch, looks like its to the dealer to fix this, thanks.
Old 10-06-2009, 07:11 AM
shorebird's Avatar
The clock spring can be changed by a reasonably skilled mechanic. I'm currently waiting for a replacement for the one in my tow truck. I did the spring in my '05 Taurus after the wreck in '08 when I replaced the deployed airbags.
Old 10-07-2009, 01:47 AM
mattsautobody442's Avatar
mattsautobody442 mattsautobody442 is offline
mattsautobody442 is starting off with a positive reputation.
yeah.. clockspring... everyone else was saying it, i just wanted to be popular.... the airbag is usually the difficult part
no horn or cruise blown fuse 37 troubleshoooting help. andy9743 Excursion - King of SUVs 16 06-15-2016 06:25 PM
Horn not working Frank33884 1968-2013 Full Size Vans 15 03-23-2016 11:29 AM
Horn Issues Snapper3 6.0L Power Stroke Diesel 15 11-09-2012 04:42 PM
Horn/Cruise Control issues ochesdoches 1997 - 2003 F150 1 11-09-2011 02:32 PM
Three problems at once! vandemonium 1968-2013 Full Size Vans 21 01-04-2011 06:04 AM
Tags
2000, 2003, 2005, air, airbag, bag, control, cruise, f150, f250, f350, fix, ford, horn, light, taurus, truck, wiring, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
